Old 10-15-2010, 09:57 PM   #1
Lifan 200cc OHC wiring diagram anyone?
My motor for the XR came today. No instructiuons or wiring diagram. Can anyone help?
Old 10-15-2010, 10:27 PM   #2
mizke   mizke is offline
damn good luck man, i hate dealing with wires.. shouldnt be to hard tho, just might take a few hours of research..
200cc beast replica,carsoli cdi,performance coil,fmf powercore 2,uni air filter,hour/tach meter,jetted mikuni carb,msr bars,moose racing grips,yz250f clutch perch,D.I.D chain
Old 10-15-2010, 10:34 PM   #3
I'm hoping one of us has done the homework already!
There is a tiny bundle of about 5 wires, very small gauge. I'm thinking that's for the gear position indicator and neutral light, I don't know. Then theres a CDI, and the coil, what I think is a regulator/rectifier, a solenoid...
The XR motor only had like 4 wires total.
Old 10-15-2010, 11:20 PM   #4
katoranger's Avatar
www.dratv.com may be of help.
http://www.hooperimports.com/showpages.asp?pid=1013
The hooper link will probably get you going.
Old 10-16-2010, 06:25 AM   #5
BillR   BillR is offline
'Course we have... :wink:
Mblas3 photo gallery
I was having a fit with a headlight problem and worked with Mark's diagrams. Very helpful.
The "tiny bundle" is the for gear indicator light. You'll have a lot fewer wires than on the diagrams due to "no lights".
Good luck.
Bill R
Old 10-16-2010, 12:20 PM   #6
Thank you gentlemen.
I will try to make the time to install the motor this weekend.
My nect challenge, after the wiring, will be the countershaft sprocket.
The motor has what looks like a 428, the XR is a 520. I'm hoping my old XR sprocket will fit on my new Lifan engine.
Old 10-16-2010, 02:20 PM   #7
i would assume you would be able to swap a 520 sprocket on it. but after dealing with the wires its all down hill from there.. just dont forget to do a proper break in on the motor
Old 10-16-2010, 07:01 PM   #8
The new motor is in.
Pretty much a direct fit.
The new intake boot was not angled right so I used the old one. Other than that it was straightforward.
The old sprocket does not fit on the new countershaft. The opening and the grooves are a little too small.
I may have to order an $80 special one from Hooper Imports unless someone knows what sprocket will fit an OHC Lifan but 13 teeth in size 520.
I have to go do the carb cable, then I'll look at the wiring. I also have to decide if I will go electric start or kick. I'm leaning towards electric.
Old 10-16-2010, 07:12 PM   #9
katoranger's Avatar
Doc, here is the sprocket info.
http://chinariders.net/modules.php?n...ewtopic&t=1393
Old 10-16-2010, 08:29 PM   #10
Thanks!
My question is then why won't my XR sprocket fit? I'm puzzled. I'll have to get my calipers out and measure. I should get a pair that are metric.
I have the wiring almost done, but I have to leave the house now and won't get a chance to finish it tonight. Maybe I'll start it tomorrow if I'm especially blessed. Then I may only be a sprocket away from riding.
Right now it is wired without a battery but I can always update it later.
Old 10-16-2010, 09:10 PM   #11
very nice doc, hope you took some pictures.. dont need a write up on it but pictures would be awsome. it would be almost like we all where in the garage with you while you did it..
Old 10-17-2010, 01:38 AM   #12
I wish you all were here, I could use help!
This is one of those projects that is bigger than it seems, it's all in the details!
Tomorrow I will try to file the inside of the XR sprocket to see if I can get it to fit.
Old 10-17-2010, 12:01 PM   #13
no matter how big the project, its always small when you break it down into steps and knock one out at a time.
thats what got me with jetting my carb. i looked at it as a whole, but when i started looking at it at one step at a time, it got easier
Old 10-20-2010, 04:13 PM   #14
katoranger's Avatar
I am thinking that the wiring may be waiting for you when you get home. If not should be tomorrow.
Old 10-20-2010, 05:21 PM   #15
It was not in the mail today. Hopefully tomorrow.
Still waiting on the sprocket, fork seals, Uni filter, and battery so there is still a ways to go. I hate not being able to finish and ride this thing, today is so nice and I have the afternoon off to work on it...
Any word on those tires?
