Old 11-12-2010, 03:52 PM   #1
Reveeen   Reveeen is offline
Treat Land
Treatland:
http://www.treatland.tv/default.asp
Bought one of these:
http://www.treatland.tv/OKO-26mm-ree...reed-block.htm
8, count them, 8 days delivered to my door (shipping cost $7.10)
This may be of some interest:
http://www.treatland.tv/OKO-24mm-int...ke-pitbike.htm
(screw a 24mm spigot mount carb to your horizontal Honda clone)
Old 11-12-2010, 10:11 PM   #2
Cool site! I promptly bookmarked that weirdness. I haven't heard the name Dellorto for awhile, not since playing with VW's.
I presume the reed block is going on your Aero 80 project. There will be precious little restriction.
What is the benefit of a spigot mount carb over a flange mount?
Old 11-13-2010, 12:38 AM   #3
Heat isolation.
The disadvantage is possible excessive vibration. I had an old Norton one time that I had great difficulty installing Lectron carbs on because the carbs vibrated at speed so much the mixture would not remain consistent.
http://www.lectronfuelsystems.com/
Old 11-13-2010, 12:54 AM   #4
So, if you installed a spigot mount, it would be wise to fabricate a solid mounting bracket. I'm guessing that you could pick up off of two carb bowl screws.
Regarding flange mount carbs, did you ever complete your Gio / Jawa project?
Old 11-13-2010, 02:14 AM   #5
Usually the carb is well supported between the spigot and the air cleaner, you remove the factory air cleaner and hang K+N's, or the like, off the end, and you have to watch the condition of the spigot, that said, I haven't had any trouble, and I suspect new Lectron carbs have fuel baffles in the bowls, because they are promoting them for Harley's (though that means little).
The Jawa/Gio is done except for a small bit of wiring. My kitchen messed with EVERYTHING around here this summer.
Old 11-13-2010, 03:36 AM   #6
Copy that. I can finally see light at the end of the tunnel, and it's not a freight train coming at me.
