05-05-2011, 10:17 PM | #1 |
My QH250-GY Komoto.. project?
I'm not sure if I'd call it a project, but this is where I'll ask all of the questions I encounter :P
Anyways, in my introduction forum I had a couple people tell me to try using a different kind of oil. Weldagrind also suggested I clean the filter when I change the oil, but I honestly have no idea where that is. I took some pictures, and I'll check this topic when I get home tomorrow and try it out. Right in the middle is where i put in the oil, but it's all dry. I'm wondering how it runs out of oil so fast, it only has 1700 miles on it. I've filled it up at least 3 times. And then heres the oil stick, which is very, very low. So my question now is 1. Should I just fill the oil up, or try and change it? I looked inside and it looks bone dry. 2, how do I clean the filter? And then heres a picture of the whole side of where i insert the oil, i'm assuming the filter would be on this side somewhere. ps: it's 9:00pm here so it's dark, I had to use a flash light to get the photos to light up(the camera flash made the pic plain white), so if needed I can take some more tomorrow, closer up of where you might think it is. Thanks in advance for the help |
05-05-2011, 10:58 PM | #2 |
Nope, the filter is on the left side, just in front of the shifter, way down low. It takes either a 24mm or 15/16" socket, and there will be a cleanable filter and a spring in there. Note how it comes out so you can put it back the same way.
I wipe the worst off of the filter, then spray it out with some carb cleaner or brake cleaner. Be careful tightening the nut back in, they crack really easily. When you're checking the oil, don't screw the dipstick in. Simply insert it in the hole so it rests on the nut, then pull it out to check. You're likely not using near enough oil.
05-06-2011, 12:16 AM | #3 |
Thought I'd check this before I go to bed.
Alright, I just went and looked with a flash light and I believe I see what you're talking about. The dip stick remains the same, no matter if it's screwed in or not. Before I took the picture I forgot that I was supposed to stand the bike off the kick stand, which I just did, and it didn't change at all. I'm pretty sure I'm using enough oil, it takes quite a bit when we fill it up. Beneath the motor is the shield thing, right? It almost looks like there's some oil on there, i'll check it out when it's daylight though. |
05-06-2011, 12:36 AM | #4 |
My point is that if you were filling and checking with the dipstick screwed in, you weren't adding enough oil. Not screwing it in will increase the total volume to a little over a quart.
Yeah, you might have an oil leak. Maybe the drain plug is a little loose.
05-06-2011, 03:06 AM | #5 |
I suggest you carefully check your bike for oil leaks. If you don't find any leaks, you are probably not adding enough oil, as Weldangrind has suggested. When you use the dip stick to check the oil level, do not screw it into the engine.
05-06-2011, 01:11 PM | #6 |
One easy way to find out.
After you warm the bike, pull the screen (filter) from the left side, as W&G suggests and then drain it all out. Put the screen, spring and cap back on and dump in a quart. That's all they hold. At least you know it has the correct amount of oil then. Cheap insurance. If you overfill, it will blow out the excess, as we've seen here in another post.
05-07-2011, 01:33 AM | #7 | |
05-07-2011, 07:02 AM | #8 |
For oil that is inexpensive yet works great. Shell rotella 15w40 available at walmart. It is for diesel engines, but does not have the energy conserving label.
Comes in qts too. http://www.shell.com/home/Framework?...on_detail.html I always used a qt to fill mine.
05-07-2011, 04:15 PM | #9 |
Well my dad went and bought some 4 stroke motorcycle oil, valvoline 10w-40. Bought to go change the oil, i'll let you guys know how it works out.
PS: I won't be able to ride it yet, apparently on the end of the steel cable needs to be a knob that goes onto the lever. That's missing, so we're going to have to get a new one. Edit: Okay, I drained the oil and cleaned the filter, no problem. What surpised me was how little oil was in there, when I had put in probably a total of 2 quarts since I got the bike. So then I put about half a quart of oil in it when I notice it was dripping oil(I thought it was just because i missed when I started pouring), but it was pretty steady stream. I looked underneath and it almost looks like a screw is missing. Heres a side view(right side) Then heres where it looks like a screw is missing. I'm 99% sure it was leaking and not from me spilling. |
05-07-2011, 08:37 PM | #10 |
It's tough to see from that photo. My recommendation is that you remove the skidplate from the bottom of the engine and clean the underside really well. After it's clean, pour oil in again, and watch carefully for the source of the leak.
Can you show us a pic of what you mean by the knob on the lever? Which lever?
05-07-2011, 09:51 PM | #11 |
Yup, me and my dad already talked about taking that cover off to look at it better.
As for the lever, its the clutch lever. From the way I understand it, you have the outer black protector cable, then inside that is a steel cable. On the end of the steel cable should be a knob that fits inside the clutch lever, so that when you pull the lever it pulls the steel cable. I can't take pictures tonight but I can take some before drivers ed tomorrow. |
05-07-2011, 10:07 PM | #12 |
You are blessed to have a dad to do these things with.
Happy to serve. |
05-08-2011, 02:01 AM | #13 | |
Buy a spray can of brake cleaner; the cheapest stuff you can find. After you remove the skid plate, spray the bottom of the engine with the brake cleaner. Then hose the crude off the engine. Once the engine is clean, it will be much easier for you to find the leak. Spud
05-08-2011, 07:34 PM | #14 |
Well, apparently my bike is not leaking oil.. I just missed. And when I missed, it just looked like there was a ton of oil coming out, when really, there wasn't. Now all I have left to try is fixing the clutch cable before I have to try replacing the clutch assembly.
Heres the pic of the cable and lever, weldangrind. PS:Yes, my battery is taped on :P If only I had the chinese bike checklist when I bought my bike. |
05-08-2011, 07:37 PM | #15 | |
