Originally Posted by MizzouFan
Got the new NGK plug, what's the gap need to be set at?
And the Mikuni carb adjustment, is the fuel mixture on the bottom by the bowl and idle adjustment on the side of the carb?
Thanks!
Off the top of my head, I think the plug gap is 28-32.
The idle mixture screw is the one that points upward next to the float bowl.
The idle speed screw is the one in the side/bottom of the slide bore that the slide sits on. It takes a flat blade screwdriver.
Make sure you check and see what slot the needle clip is in before you install it. I go either the middle (3RD) slot or the 4th slot down.
