Thread: Templar X 250
Old 07-16-2022, 10:44 AM   #384
Originally Posted by Teklock View Post
Unless these bikes are on the EPA's "Annual Certification Data" spreadsheet I would not believe it. Unless they are off road use only. https://www.epa.gov/system/files/doc...6-present.xlsx
Unfortunately, it looks like the engine mounts on the NC450 are very different. NC300 four valve engine (ZS174MN, that makes 25hp also seems very different. OEM 249cc ZS172FMM-3A has ~90mm between forward two mounting positions and ~160mm between the rear two mounting positions (this one):
https://aj1moto.com/collections/engi...-cb249f-engine
On the other hand...the PR250 (ZS172FMM-5), which is a 6 speed and has the balancing shaft, appears to have the same bolt pattern as the ZS172FMM-3A (stock engine on the Templar X):
https://aj1moto.com/collections/engi...n-pr250-engine
Even if it fits though, this is a modest upgrade: same hp rating, but with a sixth gear and the balance shaft.
So, unless someone has a good suggestion, I see no viable direct replacements for the stock engine besides the PR250, which isn't really worth the money for an extra gear.
