Old 08-22-2008, 12:57 AM   #6
dieselhead   dieselhead is offline
Seeing how no one steped up with the info right off, it looks like you will have to measure your center hole and bolt circle diam in mm. Then go to the JT sprocket web sight and start with the Jap bike listings and match your specs to the drawings that come up for each 175 to 250 sized bike. Time consuming.....it is but that is how I found a very close match to a 200 zongshen (Yamaha) rear sprocket.
Good Luck
