Old 08-15-2008, 02:46 AM   #1
RealHimura   RealHimura is offline
Skyteam ST 200 Sprocket, please help!!!
Hello everyone, I'm new around here, and have found this forum unbelievably useful. Nevertheless I haven't been able to find which sprockets do the Skyteam ST 200 ones are interchangeable with. I'm really needing a bigger sprocket for off road use. I have checked local dealers, abroad dealers, the net, and I have not found this information. Please, someone help me here!!! I have surfed hundreds of ebay sprocket listings trying to find a similar sprocket and have horribly failed!!!
BTW, the bike is the same as United Motors DSF 200 too. Thnx.
Old 08-15-2008, 03:21 AM   #2
czowner   czowner is offline
Have a look at this thread:
http://chinariders.net/modules.php?n...asc&highlight=
I've found that there are two sizes for the splines on the front sprocket, 4mm (ref:259-**) and 5mm (ref:264-**).
Jonathan.
Old 08-16-2008, 03:12 AM   #3
Thanks a lot for your answer, I had already seen that thread before I asked, but I was more likely searching for the rear sprocket, not the countershaft one. The problem with my bike is that it doesn't use the usual honda rear sprocket, it's quite different with six holes in it instead of four.
Old 08-17-2008, 02:38 AM   #4
warrior91   warrior91 is offline
If you can find a sprocket that is the same I.D. as old sprocket and the right amount of teeth, you should be able to take it to a Machine shop and get it drilled using the old sprocket as a jig.
'91 Yamaha Warrior- stage 2
'83 Honda ATC 70
'08 Yongjiang 125cc mx (Loncin)
'08 Yongjiang 150cc atv (Jinlong)
Old 08-19-2008, 12:46 AM   #5
Great idea. Thnx!!
Old 08-22-2008, 12:57 AM   #6
dieselhead   dieselhead is offline
Seeing how no one steped up with the info right off, it looks like you will have to measure your center hole and bolt circle diam in mm. Then go to the JT sprocket web sight and start with the Jap bike listings and match your specs to the drawings that come up for each 175 to 250 sized bike. Time consuming.....it is but that is how I found a very close match to a 200 zongshen (Yamaha) rear sprocket.
Good Luck
