Old 04-23-2019, 08:07 AM   #1
Audihuff   Audihuff is offline
Audihuff's Avatar
hawk 17t front 50t rear
So i just pt on my 17t front sprocket on my hawk. It has stock chain & stock 50t rear sprocket. I dont know how tight yall chain are with this set up, but mine is way too tight! making some odd clanking noise at low speeds.. i run 70 percent on road. I was wondering what other sprockets can i use with stock chain? I dont want to cut the chain but i will if needed. Just a complete noob here I love the feel of the bike with 17t x 50t... is adding a link to the stock chain a possibility?
To light a candle, is to cast a shadow..
Old 04-23-2019, 10:23 AM   #2
Ariel Red Hunter's Avatar
Yes. It is called a "cranked link". Any Japanese bike shop should have them in stock...ARH
Old 04-23-2019, 11:03 AM   #3
You can also get a half link if you just need a little more slack.
https://www.amazon.com/4-Pieces-Offset-Crank-Motorized-Bicycle/dp/B01MRC279B/ref=sr_1_fkmrnull_1?crid=3240AUCZ1EJGJ&keywords=42 8+chain+half+link&qid=1556031914&s=gateway&sprefix =428+half-link%2Caps%2C198&sr=8-1-fkmrnull
Link is for reference. I would search for a better quality designed for motorcycles.
Old 04-23-2019, 11:48 AM   #4
Audihuff's Avatar
thank you guys! i ordered a dirtbike jack/stand, some of those 1/2 link, and a 45t rear sprocket! should be a fun couple of days!
Old 04-23-2019, 11:49 AM   #5
https://www.amazon.com/4-Pieces-Offs...r=8-1-fkmrnull
Yes, that's what I was talking about. If you look at the picture in the ad, you'll see how it got named a "cranked link."...ARH
Old 04-23-2019, 11:52 AM   #6
The 130 link chain should work fine with the 45 tooth rear.
Old 04-23-2019, 02:00 PM   #7
You shouldn't need anything else once the 45 is in place on the rear.
Old 04-23-2019, 02:49 PM   #8
Audihuff's Avatar
Awesome! I get the 45th tomorrow morning. then i take my motorcycle license text friday!
Old 04-24-2019, 08:13 PM   #9
Sochin   Sochin is offline
Sochin's Avatar
Get a wee bit longer chain, I've run this 17/50 combo for 2 years and love it. I have a conventional chain, because at the time everybody got Hawk's so Amazon was out of X and 0 ring chains in the 428.
1983 Honda Xl600R
2016 Ducati Multistrada 1200S DVT
Old 04-29-2019, 01:36 PM   #10
The_DJ_Remixer   The_DJ_Remixer is offline
13f/35r <----is this the combo for the 520 chain. sprockets?
Old 04-29-2019, 01:58 PM   #11
If your goal is to match the same ratio as a 17/45 for a 428 chain, yes.
If you want to closely match a 17/50 then use a 12 tooth front for a 12/35 or a 13 front 38 rear
Old 04-30-2019, 07:24 AM   #12
OneLeggedRider's Avatar
I'm running the 520 12/33 because I wanted to mimic the 428 16/45. I'm very happy with it, still has plenty of bottom end offroad and not buzzy at 55mph. I think I could get away with gearing it even lower because I'm nowhere close to topping it out in 5th gear.
