My latest issue - Apollo db 36
It appears I got the lemon of this particular litter. Occasionally when I go to shift from first to second, I think that's the only time it does it maybe 2nd to 3rd also, the damn thing will not upshift unless I pull in the clutch, slow down, downshift then continue to upshift. It doesn't do it every time in fact sometimes I can ride around the neighborhood for 15 minutes and it wont do it at all. Orion powersports suggest I might need to adjust the clutch but I'm sceptical and think it's something internal.
Sound familiar to anyone? Thanks, Dean. |
Adjust the clutch with minimal play in the cable. Sounds like you have too much play and the clutch is dragging. Follow these instructions on how to adjust. https://www.cscmotorcycles.com/check...and-adjustment
2025 Lifan KPT 400 2024 Linhai 300 ATV 4x4 2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 (Sold) 2016 Black Hawk 250 (sold) 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel |
#3 | |
These cheap clone motors have cheap clone clutches that suffer from quite a bit of clutch fade as the oil and clutches get hot. I often had to adjust my clutch at the lever after riding for a bit so that it would fully release. When it cooled off again it was almost too tight. Eventually I found a middle ground that worked well.
#5 | |
BuffaloChinaRider on Youtube Bashan Storm 250 (2018) Apollo Db-36 Deluxe (2019) |
