View Poll Results: what should i do
buy a new bike 4 50.00%
or try to find the part 4 50.00%
Voters: 8. You may not vote on this poll
Old 11-03-2007, 10:35 AM   #1
idcountryboy1   idcountryboy1 is offline
stomp in to oil case of db-27
hello i am having a crapy week. now i am only 16 and have been riding for a year. i had pooped a tube about two weeks ago i finally got a tube that didnt have a hole in it.I put it in and it was perfect it only took half a can of wd-40 i then went to test it in the night i dont have a head light) i did have a jury rigged flashlight mount that works most of the time. but this time i tryed my new headlamp and put it over my helment ididnt work i hit a stomp. It wasnt a big one but the way i hit it,it went right into my oil case and threw my guard (by the way roketa brush guard sucks) so if any one know where i can get another please email me at idcountryboy1@aol.com thank you guys so much for listening to my whining
db-27 stock
Old 11-03-2007, 01:19 PM   #2
I have been through 2 200cc engines with less than 1000 miles. I knew that I wasn't getting a Suzuki, but TWO engines?!? I am ditching the Jetmoto, debating parting it out as it must be cursed and wouldn't want to bring bad luck to anyone else, and working on a Qlink XF200 with the Suzuki-style/derived engine.
In your case, at least try a new engine first...I wouldn't trust repairs for the life of me! I hope you have better luck than me...
Old 11-05-2007, 07:13 PM   #3
katoranger's Avatar
Sounds like you need a case of JB weld.
You may be able to locate a replacement set of engine cases to replace the damage one. Did it cause any internal damage?
Allen
Old 11-05-2007, 07:36 PM   #4
ejcycles   ejcycles is offline
ejcycles's Avatar
Hi idcountryboy1
What engine do you have? Over Head Cam or Push-rod? I have a set of A. Lifan 200cc Push-rod engine cases from a GY-5. It will take removing the engine from the frame and completely disassembling it and then putting it back together. Let me know.
Thanks, Bruce @ Endless Journey Cycles
"Phone Calls Only" ~330-274-0098~
Hours: Tue.-Fri. 10:00-6:00 Sat. 10:00-4:00 EST.
Dealer for: Lifan, Crossrunner ATVs.
http://www.endlessjourneycycles.net
Old 11-06-2007, 09:39 PM   #5
jb weld
yeah jb weld is what a buddy of mine said to
Old 11-06-2007, 09:44 PM   #6
it did not do any internal damage and i have no idea if it is a gy6 gy5 or what all i know is i am pissed and i need my dad to get some jb weld
Old 11-06-2007, 11:04 PM   #7
katoranger's Avatar
Clean the case really well and use some sand paper to rough the area and remove any paint where you are going to put the JB weld. Get the 24hour stuff not the 5 minute and let it sit for at least one day.
I have use it to fix many things, but don't rush it. It needs time to cure.
If the hole is too big then replacement cases or engine is in order.
Allen
Old 11-13-2007, 03:03 PM   #8
i hope it fixed
well i went and bought some jb weld my dad said he would do it but had to leave for training on nirvana air compressors he is in north carilina i havent told him i did it so hope fully it works cause then he wont be mad just proud so wish me luck i am going to let it dry for 24 hours so thanks guys
Old 11-13-2007, 09:17 PM   #9
katoranger's Avatar
Good prep goes along way. It may not be pretty, but better than buying a new bike.
Allen
