Old 08-06-2008, 09:15 PM   #1
jayg   jayg is offline
Tach issues...
When going to start my LF200 GY this morning I noticed that my tach was stuck at 2. Can I just open the cluster housing and push it back down?
I can listen to the idle and pretty much tell where I am on rpm...
Old 09-28-2008, 09:50 AM   #2
OK it is now stuck on 6...WTF. Anyone know how to fix this?
Old 09-28-2008, 09:50 AM   #3
Old 09-28-2008, 10:37 AM   #4
DDG1976   DDG1976 is offline
Send a message via Yahoo to DDG1976
I've never had this problem, but it sounds like you might have a cable driven tach. Again I'm not sure. I think there are a couple people on this forum who have cable driven ones. You may just be able to remove the cable and let the tach return to normal and reinstall the cable.
I have all of soberday to satur up!!
Old 09-29-2008, 07:00 AM   #5
tigertamer   tigertamer is offline
You didn't mention what year bike you have!
If you have an electronic tach, The CDI drives the coil and tach.
I would assume the CDI connector is good, if your bike is getting good spark from the coil.
That leaves the connector under the headlamp fairing. Look for a Black/Yellow wire in the connector, and inspect it for tightness of fit. Also, Make sure you get battery voltage at the Black wire, and good continuity to ground on the Green wire at the same connector.
Good luck, Brother,
Tigertamer
07 H-D XL883C
06 LF 200GY-5
Yin and Yang
CAUTION
Obey The Traffic Regulation.
Always Wear a Helmet.
Don't Ride After Drinking Wine.
Before Operation, Read The Owners Manual Carefully.
