hawk 17t front 50t rear
So i just pt on my 17t front sprocket on my hawk. It has stock chain & stock 50t rear sprocket. I dont know how tight yall chain are with this set up, but mine is way too tight! making some odd clanking noise at low speeds.. i run 70 percent on road. I was wondering what other sprockets can i use with stock chain? I dont want to cut the chain but i will if needed. Just a complete noob here
To light a candle, is to cast a shadow.. |
#2 | |
You can also get a half link if you just need a little more slack.
https://www.amazon.com/4-Pieces-Offset-Crank-Motorized-Bicycle/dp/B01MRC279B/ref=sr_1_fkmrnull_1?crid=3240AUCZ1EJGJ&keywords=42 8+chain+half+link&qid=1556031914&s=gateway&sprefix =428+half-link%2Caps%2C198&sr=8-1-fkmrnull Link is for reference. I would search for a better quality designed for motorcycles.
2025 Lifan KPT 400 2024 Linhai 300 ATV 4x4 2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 (Sold) 2016 Black Hawk 250 (sold) 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 04-23-2019 at 11:49 AM. |
thank you guys! i ordered a dirtbike jack/stand, some of those 1/2 link, and a 45t rear sprocket! should be a fun couple of days!
#5 | |
The 130 link chain should work fine with the 45 tooth rear.
2025 Lifan KPT 400 2024 Linhai 300 ATV 4x4 2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 (Sold) 2016 Black Hawk 250 (sold) 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel |
You shouldn't need anything else once the 45 is in place on the rear.
Get a wee bit longer chain, I've run this 17/50 combo for 2 years and love it. I have a conventional chain, because at the time everybody got Hawk's so Amazon was out of X and 0 ring chains in the 428.
1983 Honda Xl600R 2016 Ducati Multistrada 1200S DVT |
13f/35r <----is this the combo for the 520 chain. sprockets?
#11 | |
If you want to closely match a 17/50 then use a 12 tooth front for a 12/35 or a 13 front 38 rear
I'm running the 520 12/33 because I wanted to mimic the 428 16/45. I'm very happy with it, still has plenty of bottom end offroad and not buzzy at 55mph. I think I could get away with gearing it even lower because I'm nowhere close to topping it out in 5th gear.
