Old 04-01-2015, 04:46 PM   #1
hect75   hect75 is offline
hect75's Avatar
tubeless tire
Hola Chineros, I need a front tire and found a btrubber 100/90 18 (http://rr.runrun.mx/index.php?id_pro...roller=product). I need the tube type but the seller only has the tubeless tire because the another one will take, at least, two weeks to get it plus another week to ship me. I asked in a motorcycle shop about tube and tubeless and told me that if the rim has spoke I need a tube type. Should I wait or get the tubeless tire?
Hector
Mountrack Vento 2006
Old 04-01-2015, 05:23 PM   #2
hect75's Avatar
There are some sizes 90/90 18 and/or 3.0/18, can I use this size?
Hector
Old 04-01-2015, 05:29 PM   #3
Mudflap   Mudflap is offline
It's ok to put a tube in a tubeless tire.
Old 04-01-2015, 06:36 PM   #4
alex_in_az   alex_in_az is offline
I have 3.00/18 on both my wheels
2020 Tao TBR7
9.3:1 PnP head
CRF230F exhaust
4 degree advance key
290 degree cam
Nibbi PE30 and cone filter
Front fork brace
Old 04-02-2015, 02:43 PM   #5
Either size tire will fit your front rim.
You do need an inner tube because your front wheel has spokes. I agree with the others; it is perfectly fine to put an inner tube inside a tubeless tire.
Old 04-01-2015, 05:48 PM   #6
guttafixit   guttafixit is offline
guttafixit's Avatar
If you do put a tube in the tire I would get a heavy duty tube. I bought both for mine and what a huge thickness difference between stock and heavy duty.
Old 05-11-2015, 02:49 PM   #7
hect75's Avatar
Hola Chineros, I installed a new front tire (90x90 18) two months ago. Below some pics of Vento taken at my work place in the Chihuahuan desert.
Saludos
Hector
Old 05-11-2015, 03:36 PM   #8
Thanks for posting the update.
Old 05-12-2015, 05:14 PM   #9
hect75's Avatar
Chineros, what kind of gasoline are you using on the sierra? I am using 80 octane and doing 22-24 km/l which I think is very low. Should I use above 90 octane? The tw200 owner manual says use regular gasoline (below 90 octane)?
Thanks
Hector
Old 05-13-2015, 04:51 AM   #10
Pliskin   Pliskin is offline
Thanks
I use 91 octane on my zong and get around 2.7 litres per 100km sometimes even less, but my cruising speed is 50km/h.
Zongshen 200gy-2
Old 05-13-2015, 02:19 PM   #11
hect75's Avatar
My cruising speed is 80 km/h, the Vento weight about 135 kg and I weight about 83 kg, could these variables making my low km/l (MPG)? I saw the Honda XR 150L that gets 48km/l at 60 km/h. So at very low speed all bikes will get decent MPG, right? I wonder the cruising speed of those who are getting more than me.
Hector
Old 05-13-2015, 07:00 PM   #12
It's possible. My stats are based on 50km/h also mine has 16tooth front sprocket, apart from that it's stock. Everything changes the faster you go. You have different muffler and not sure if you changed jets too from the stock ones. Also it depends on your riding style. Not sure what is Spud getting?
Zongshen 200gy-2
Old 05-11-2015, 10:12 PM   #13
I like the attitude your bike has, mostly due to that tank.
Old 05-12-2015, 05:50 PM   #14
ripcuda   ripcuda is offline
ripcuda's Avatar
I need to find a bigger tank like that for my bike. I got a tiny tank.
Regular gas in the US is 87 octane (R+M)/2... I found this on the web regarding fuel in Mexico...
MAGNA
This mid-grade fuel is sold from a bright Green pump, and is Mexico's most popular unleaded gasoline. (Regular Unleaded 87 octane). Most vehicles will run acceptably on "Magna" (as it's popularly called in Mexico).
I would think that is what you want to use.
Cheers
'20 TaoTao Hellcat 125 "grommet"
'04 Yamaha TTR-125LE
'00 Yamaha TTR-90
'07 Kinroad XT200GY Runmaster (sold)
'07 KMD GY6 150cc ATV (sold)
'07 Kangchao 250cc ATV Monster (sold)
Baja Moto DB-30 "Doodlebugs"(x3) (sold)
'06 Hi-Bird 200 parts bike (sold)
Old 05-12-2015, 06:59 PM   #15
humanbeing's Avatar
Tries 3:1 [MAGNA / PREMIUM] because LY200 c/r is 9.5:1 |http://www.carbibles.com/fuel_engine_bible_pg3.html http://tw200forum.com/forums/99648/ShowPost.aspx
