Old 09-10-2016, 02:52 PM   #1
Nithious   Nithious is offline
Nithious's Avatar
Send a message via MSN to Nithious
Hawk sprockets for street
I am probably going to be using my Hawk 95% on street what is the best street sprocket setup? Right now I have a 17t front I wasn't sure about the rear. ( I have no hills on my commute to work or most my joy rides)
Old 09-10-2016, 03:04 PM   #2
Eldric1   Eldric1 is offline
Weight of rider seems like it matters. Most popular is 17/45 but that would not work well for me.
Old 09-10-2016, 04:35 PM   #3
Ariel Red Hunter's Avatar
Maybe 16-45?
Old 09-10-2016, 05:25 PM   #4
Nithious's Avatar
What rear sprocket pairs with 17t front?
Old 09-10-2016, 08:18 PM   #5
chuck   chuck is offline
17t-39 if you weigh less than 180 pounds over I say 17t-42t.
Old 09-10-2016, 08:24 PM   #6
Azhule   Azhule is offline
17t - 43t (over a 42t) or a 17t - 39t combo will save some excess ware on the chain and sprockets (if your chain has even number of links)
Old 09-12-2016, 09:59 AM   #7
Fame28   Fame28 is offline
The 17-45 combo is very common swap for the Hawks. I have it on mine and it just about the perfect setup for the road. If you go too low of a rear sprocket the motor won't have enough horsepower to move it along at the higher speeds with enough torque and the motor will be lugging... The 17/45 combo requires the removal of two links on the chain. I would very highly recommend just ordering a good chain when you replace the sprockets. The chains on these bikes from the factory stretch a lot. Also important info would be to make sure you have a not cheap set of snap ring pliers. The rear snap ring on the back wheel to change the hub is super strong and almost impossible to remove without a good set. A final recommendation would be to use a little loctite on the rear bolts when reinstalling (which you should do on every single bolt on these bikes.
Old 09-12-2016, 06:48 PM   #8
Nithious's Avatar
Haha yeah I notice a few bolts got a bit loose, I been trying to get them all with loctide the removable kind. Can you you please send me a link for the rear 45 sprocket?
Old 09-25-2016, 08:33 PM   #9
fredweb   fredweb is offline
loose bolts
I wired my bolts on the sprocket and brake calipers/rotors to ensure nothing came loose while riding. Just drill a small hole in the bolt head and feed wire through and tie the ends. Tie as many bolts together as possible. This way you wont lose any and you wont have anything getting too loose while riding and damage yourself or the bike. Use this in addition to loctite.
Old 09-25-2016, 10:51 PM   #10
I agree with fredweb. Safety wiring nuts and bolts is the best way I've ever found for security of fasteners.
Old 09-13-2016, 08:43 AM   #11
wilserchinarider   wilserchinarider is offline
https://www.amazon.com/JT-Sprockets-.../dp/B0068O5W3M
I have a 45 rear now and am thinking the 42t may be better for me
https://www.amazon.com/JT-Sprockets-.../dp/B0068O5N5Y
Old 09-18-2016, 05:20 PM   #12
210hawk?   210hawk? is offline
What are some of y'all's weights sprocket size and top end speed at? New to the hawk haven't bought one yet 55mph top is definitely a deal breaker
Old 09-30-2016, 11:37 AM   #13
I'm running 17t-39t,it cruises at 65mph-6200rpm.I think it can see 75mph top speed.I weigh around 165 pounds.I tried different sprockets combinations,with this set up the engine is running great.This is off course for street use only.
Mods so far.
Mikuni clone 115-30
Pro-circuit full exhaust
80-20 Shinko 705 tires
K and N filter
Uni bear non o ring chain
Mystef cluster
Progrip 714 grips
Ngk spark plug.
Old 09-18-2016, 06:57 PM   #14
Nithious's Avatar
I been like maybe 55ish tops stock but it's very very torque but once I change sprocket that I have already 17t and 45t from what I hear it can hit 65+ but don't quote me on that. To me this is just a good commute/fun bike around town and off-roading no highway.
Old 09-25-2016, 06:53 PM   #15
Nithious's Avatar
So my chain seems to be really really tight and I have no leeway to get it any looser with my 17t front sprocket, is that normal with the 17t 50t combo?
