Cheap fork upgrade, gain over 20% travel for under $100
I'm sure someone has already posted this but...
For less than a 100bux I increased the front travel on my tbr7. I bought a complete set of forks from a 1980 honda xr200 (not "R") for 60bux off ebay. I pulled the damper tubes which are 1.5" longer than the tao's. I swapped my plastic sliders from my tbr7 to the honda dampers as they are a little larger in diameter. Then install them in the tbr7 tubes and like magic I picked up 1.5" of travel. It's possible that your stock springs will bind before complete compression because they are made out of thick diameter with allot of coils. You will also have to make your spacers a longer, but you may not need as much preload, due to the longer travel so your overall ride should be smoother. Now what I did. The 80-82 honda uses 2 springs, a long bottom one and short one on top separated by a washer. I measured the long bottom spring and it has plenty of coil spacing for over 9.5" travel. So I only used the long spring, and made a longer spacer. I ended up about 8mm of preload. I filled it up with 10wt fork oil 120mm from top (no springs, fully compressed). Pros: it rides so much smoother. Cons: Bike is 1.5" taller in front (.75" at your feet) Brake lines may be a little short if using bar risers or tall bars. Fork boots set a little lower. I havent added a brace yet, but I will soon. Overall, it's a great cheap improvement.
2021 Tao Tbr7 - "Lucille" Mods so far- Brozz swingarm, 21" front rim (Bridgestone Tw302 rear/Dunlop D606 front tires), Digital gauge cluster, pz30b pumper carb, after market hand guards, aftermarket brake and clutch levers, round fold away mirrors, Fly handlebars shortened slightly, 13t front sprocket 2009 Q-link Legacy 250 1982 Suzuki GS1100ES - "Jolene" Last edited by TxTaoRider; 05-16-2021 at 01:10 PM. |
wow - very cool. I have an XR200R in the basement actually a bit newer than the XR200 forks you got, but that's interesting none the less.
2020 RPS Hawk 250 - Build thread can be found here: http://www.chinariders.net/showthread.php?t=28374 "Do Wheelies and Forget your Feelies" "If vegetarians eat vegetables, what do humanitarians eat?" -unknown |
Probably wont work. The non "R" use a 31mm fork, the "R" uses a 35mm I think.
That would put the front end travel at 8 to 8.5 inches.
Yes. It measures 8.0" not including compressing the top out spring, so the 8.5"-8.6" that honda specs (depending on source material) is about right including their travel added. The new damper tubes measured about 1.5" (actually 1.45") longer than the factory dampers.
In theory, since it's over 20% in additional travel, you can go 20% less in spring pressure with the same bottoming resistance.
#6 | |
![]() Quote:
