Old 06-18-2008, 02:35 PM   #1
theENIGMATIC   theENIGMATIC is offline
A few Problems???
I have a couple of problems, Im not sure if its normal but my bike idle was at around 1200 rpm , I got 10mph out of it at 4000-4500 rpm???
Seems way to high......anyways I adjusted the idle screw between 1400-1800 rpm at idle, it ran a little faster about 15 mph at same rpm....the other thing Im not sure how it could be related but my steering seems alot stiffer???
I set the idle back to 1200rpm and steering is still stiff, if anyone knows anything help would be appreciated..the bike is a Huansong Viva vx200s!
Thanks!
Old 06-18-2008, 03:33 PM   #2
lego1970   lego1970 is offline
I'm not sure if I understand your question completely but it sounds like your throttle cable is being pinched, pulled, or some how tangled up and not allowing your throttle to completely close and not allowing your steering to rotate freely.
Old 06-18-2008, 04:27 PM   #3
I have nothing intelligent and helpful to say. Sorry.
Old 06-18-2008, 05:00 PM   #4
Thanks lego, I thought of that..Ill check it out more later, I think your right!
No prob Iron, its probably just something to get used to!
Thanks!
Old 06-18-2008, 05:50 PM   #5
Rizn   Rizn is offline
HA HA HA No prob Iron, its probably just something to get used to!
did u mean Irons comment or your bike
Old 06-18-2008, 06:51 PM   #6
LOL.....probably both.....nah...just kidding Iron!
Old 06-20-2008, 05:19 PM   #7
Well I thought there was a rubber band to keep grease from the bearings from leaking, but it turns out it was just dried up grease....I cleaned it up and steering is better...needs some more scraping and lube though......
Old 06-25-2008, 10:36 AM   #8
Frog   Frog is offline
I'm not sure I understand this one BUT...............
the only two common ways for road speed to vary with revs are
1. different gear selected
2. the clutch is slipping
I would check the clutch cable - that may be the one mucking up the steering also.
regards
Frog
Old 06-25-2008, 10:49 AM   #9
Guest
Posts: n/a
Re: A few Problems???
Thanks!
Is this a drunken post?? It makes no sense......
Old 06-25-2008, 10:54 AM   #10
Don't know about drunk but enigmatic is about right!
Old 06-25-2008, 01:04 PM   #11
TheBrainII   TheBrainII is offline
Reverse
Does the steering feel tight when it's in reverse?
Bone stock 2007 Lifan GY-5
Old 06-25-2008, 02:03 PM   #12
this topic is in reverse :roll:
Old 06-25-2008, 02:34 PM   #13
regards
Frog
I don't know how idle is affecting road speed?????????
I was going to say something like, release the clutch next time you're on the road
Or, are you sure you weren't in 2nd gear... That's how you go faster at the same RPM. :P :P :P
I'm learning how to keep my mouth shut, but I'm just learning. :o
Old 06-25-2008, 02:42 PM   #14
Idle speed is the minimum operating speed (generally measured in revolutions per minute, or rpm, of the crankshaft ) of a combustion engine . At idle speed, the engine generates enough power to run reasonably smoothly and operate its ancillaries ( water pump , alternator , and, if equipped, other accessories such as power steering ), but usually not enough to perform useful work, such as moving an automobile
well Im not too familiar with all the mechanical terminology but as is above my minimum engine speed was 1200rpm, at 10mph the engine speed was around 4500-5000rpm...I dont know maybe that makes no sense..
Generally I would expect rpm to drop after changing to a higher gear.my bike was not.probs fixed for now.thanks dudes! :P
Old 06-25-2008, 02:51 PM   #15
But will changing the idle speed, affect the speed of the bike at any given RPM?
