Same for me as well. I think I am going to fill it out and give it a try to get a tag.
Smoothbore Carburetor
I pulled the carb and there are just TWO break-off bolts holding the float bowl in place.
I used a fine saw this time to cut a flathead slot. STILL barely got the first one off. I actually used an impact driver. Shocked at how hard to remove! The second one was NOT as cooperative, so I ground off the head and removed the bowl. To my surprise, the shaft of the bolt was EASILY accessible. I could have just ground off the head on BOTH of them. Once exposed, it was no match for a vice grip. But the reason became obvious. They are loctite sealing these in place! HAH!!! No match for a dremel and vice grip! BY THE WAY... Threads are M4 -.7 I got a couple of 16mm Allen bolts to replace them. Last edited by Thumper; 08-31-2022 at 01:26 PM. |
carb
Are you changing jets or installing new carb?
Changing jets. It is a good smoothbore carb. And no need to open the bowl if I was just replacing the carb!
I found #120 main and #40 pilot in there. |
That jetting is pretty good for a starting point. Most have come with a much smaller main and pilot. I'm at 600' elevation and similar jetting on my vm26 with the Titan so hopefully will good right off the bat.. perhaps just need to shim the needle one or two washers... will see.. Have you adjusted the jets yet? Hoping its similar to the Titan where you pop off front and rear valve covers and align TDC @ .004?
2024 Templar 250 2021 Beta 500 RRS 2018 VStrom 1000 XT Former China Bikes: Tao DBX1, Brozz 250, CSC RX4, Titan DLX, Templar X, Storm DLX 150 |
I'd like to order a couple of parts ahead of time that i know will be changed out sooner rather than later: rear sprocket and chain..
Can anyone confirm this is the optimal rear sprocket: JT JTR210.42 I read of one member using this sprocket but they needed to open up the countersunk holes.. just would like to confirm if thats the general consensus on install or whether there is a better rear sprocket fitment. thanks
#12 | |
I went with JTR210-39T |
#13 |
Any fitment issues? I ordered the JTR210-42T. Figure if 13/42 works for Jerry on the KPX it'll work for me here
#14 |
Wow.. just found the PSM build video for the TX.. thats the most involved build of any China Bike ive seen.. install needed for the whole steering assembly, fork tubes, etc.. ok.. guess its the perfect time to slather as much grease as possible
#15 | |
I did go with 14T front, but that DOES required grinding a shield down. I will take a picture when I have a chance. I was concerned about keeping the area clean, but the sprocket cover has additional shrouding, so it's OK. I think this will be the same in the new 172-FMM-5 engine, but I might rethink the gearing now that I've ridden it. It has the power to pull 70+, but even my Tusk Dsport beast on the Storm is a smoother road tire! Last edited by Thumper; 09-01-2022 at 03:58 AM. |
