Old 07-22-2016, 01:31 PM   #1
firebank   firebank is offline
First day on the Hawk.
Put nearly 40 miles on the Hawk today after putting it together last night. Few things I noticed is the forks feel as if they are bottoming out over flat terrain. At 42 MPH I get a horrible wobble on the front end. Other than that this thing is a ton of fun.
Old 07-22-2016, 01:51 PM   #2
Change out the motor oil they put in the forks with around 150ml of ATF or 10w fork oil.
Old 07-22-2016, 02:00 PM   #3
#27
http://www.chinariders.net/showthrea...t=chart&page=2
Old 07-22-2016, 03:35 PM   #4
mq1991   mq1991 is offline
Make sure you tighten your steering stem nut and locknut, mine was loose. Your front wheel could also be out of true, maybe some loose spokes?
Hope you get it sorted! I have about 2500 miles on mine, love it.
Old 07-22-2016, 06:52 PM   #5
Got it home this evening and discovered my bike had lost spark, thinking it's a bad CDI unit. Hoping I'm not going to be working on this thing every 40 miles
Old 07-22-2016, 07:17 PM   #6
w0ss   w0ss is offline
I had all kinds of issues that cropped up on mine. But after I got everything worked out it has been problem free. Keep at it you will get there.
Hawk 250 with following performance mods: 17t, Mikuni with 110/25, Uni filter, Exhaust.
Old 07-22-2016, 07:33 PM   #7
Has anyone dealt with txpowersports.com for warranty issues. Just curious if it's a hassle and should just buy the parts myself.
Old 07-22-2016, 07:48 PM   #8
I had a bad blinker module and I sent them an email and got a replacement. It took a week and a half to get to me though. I ended up buying one myself and had it much quicker.
Old 07-24-2016, 09:23 AM   #9
wilserchinarider   wilserchinarider is offline
Not sure what parts you are talking about, a new CDI is under 10 bucks. My guess is you have a loose connection. My hawk had a loose wire plug feeding the coil which brought about intermittent running and no start issues. Once that was remedied, the bike was good.
Adjust your valves, most hawks have arrived too tight, this can lead to hard starting IME.
Old 07-26-2016, 11:49 AM   #10
Checked all connections. After a new CDI, coil, and plug no fire. Stater is generating current, not sure where it's losing power.
Old 07-26-2016, 11:56 AM   #11
Go back to the trinity...spark,air,fuel? Verify that...=bang
Kill switch?
Old 07-26-2016, 12:04 PM   #12
I thought the kill switch could be the issue to so I bypassed it with a jumper. Didn't fix it. I 've got fuel and air. I emailed the dealer yesterday still waiting for a reply. It's got to be something simple, having to wait is annoying.
Old 07-26-2016, 12:11 PM   #13
But no spark? Plug swap easy and cheap test (and it doesn't solve problems at least you have it as a backup). Wedge it on muffler to ground it and observe for spark when cranking.
Go to http://www.dansmc.com/mc_repaircourse.htm like you say, it's something simple
Old 07-26-2016, 01:47 PM   #14
http://www.buggydepot.com/tech-cente...uide-no-spark/
https://www.kazumaracing.com/trouble...s-p-13392.html
Not sure if these are the same CDI as your bike, but you get the idea. You can eliminate portions of the harness at the CDI for diagnostic purposes.
I'm sure Dan is a nice guy, but he is still talking about adjusting ignition points....can't remember the last time I saw a set of points.
Old 07-26-2016, 04:17 PM   #15
2 excellent resources, bookmarking for future reference. Ty.
Search this Thread:
Advanced Search
Display Modes
