Old 05-13-2020, 02:54 AM   #1
BrandonDorch   BrandonDorch is offline
Vader 125-10 mikuni carb upgrade
so I put a mikuni knock off carb on my vader. Ive already put it on did the block off plate on the head removed the charcoal canister and it starts right up easy and idles great.So what do I do to the line that comes out of the gas tank that was attached to the charcoal canister? Do you use the port in the side of the new carb for anything?
Old 05-13-2020, 06:07 PM   #2
ripcuda   ripcuda is offline
ripcuda's Avatar
On my Hellcat 125... I too removed my fuel vent canister, but have not decided what to do with the fuel tank vent line yet. For now it's just running down along the frame. I've never filled my tank to the brim... so I'm not sure if this vent would ever drip raw fuel or if it's baffled in the tank to only allow fumes out. On all my dirt bikes the vent is in the gas cap and a simple hose is routed up over the triple tree. I think once I put my plastics back on, I'll ziptie the vent hose as high as possible somewhere it can just vent.
Are you using the stock airbox? Does your Vader have a crankcase breather hose? I have one on my Hellcat still connected to my airbox... but am planning to go VM22 Mikuni and pod filter and will have same issue with this hose. I guess I'll just ziptie it off somewhere up high and let it breath. Or maybe fit a barb on the pod filter to connect it.
Cheers!
'20 TaoTao Hellcat 125 "grommet"
'04 Yamaha TTR-125LE
'00 Yamaha TTR-90
'07 Kinroad XT200GY Runmaster (sold)
'07 KMD GY6 150cc ATV (sold)
'07 Kangchao 250cc ATV Monster (sold)
Baja Moto DB-30 "Doodlebugs"(x3) (sold)
'06 Hi-Bird 200 parts bike (sold)
Old 05-13-2020, 06:51 PM   #3
So I have removed the stock air box and am using a double like foam filter that came with the new carb...yes I have a crank case breather on my bike and I have a small pod style filter from advanced auto parts on that zip tied up in the frame...i have a small 110 atv that vents the gas tank out the cap and has a small breather thing on it im think about buying one of those and putting it on there I guess...I'd post pics but not sure how to do it
Old 05-16-2020, 02:44 PM   #4
Ninjaguy23   Ninjaguy23 is offline
Ninjaguy23's Avatar
What did you use for your emissions block off plate??
Old 05-16-2020, 05:16 PM   #5
The block off plate from a Gy6 fits perfectly, you can find it on Ebay. Oh hell, i 'll give you the link :
https://www.ebay.com/itm/Universal-E...MAAOSwCMtacNc1
2001 Mustang GT
2004 Sportster
2018 VADER
2020 Orion RXB250L
Old 05-16-2020, 09:08 PM   #6
SilverBullet51   SilverBullet51 is offline
On my wife's bike I cut the hard pipe off the egr, and took it off and shoved a penny over the hole. Put the plate back on sandwiching the penny against head. It's a 1 cent block off plate. And it's sealed tight.
Old 05-17-2020, 09:19 PM   #7
I cut the tube off the plate that was on the bike and used my harbot freight 99 bucks welder and just welded the hole closed
Old 05-20-2020, 08:03 PM   #8
Ninjaguy23's Avatar
All Good info!!
Thanks for the link Crow!!
Cheers!
125cc, boom, clone, grom, vader
Search this Thread:
Advanced Search
Display Modes
