Old 11-28-2022, 03:02 PM   #1
FYI, Texas Pete went to #42 on the pilot instead of #45. And he adjusted the pilot screw accordingly. My #45 is probably fine where I live (~800 feet), but even when it is cold, I barely need choke on a cold start.
I am only at the following,
Elevation: 182m / 597feet
Barometric Pressure: 99KPa
With the Air Pilot screw on the default 2 turns out the #42 jet ran fine, I have mine at the moment set to 2 1/2 turns out and left it there to see how it goes over time.
#40 is the default jet and the factory sealed Air Pilot screw was set to a hair over one turn out. If you are a turn out or under you definitely need to think about rejetting your pilot. Being just over one turn out in the factory state it was on the edge of needing a new pilot (running lean) and was popping on deaccelration.
Now I just need to run it over a full set of seasons and monitor how it goes.
Search this Thread:
Advanced Search
Display Modes
