Who knows about brakes?
Hey guys, long time no see...I have been in New York visiting my folks for the past few months and I went completely with out electronics the whole time, just some good dirt riding.
Anywyas, I'm back here in florida, and now I have a problem I need help with. It seems my master cylinder on my front brakes is bad, when I squeze the lever, the plunger stays in, seems the spring is bad. Anywyas, I looked all over for a new one, and it seems there are many like it, except with out the mirror screw hole. So I am wondering, if I could get a smaller one, witht he whole, and it will do the same job as the one I have now. 08 Diamo LS200 Simular to the roketa DB-07 and the Zongshen Ls200 thanks for the help, Rando |
If the brake master cylinder is the same, except for the mirror mount, you should be able to use it.
![]() ![]() Spud ![]()
Well thats the problem, I would like to have to avoid a seperate mirror mount, because then I would have to get a different mirror mount for the other side, so that it will match.
I am wondering if the smaller master cylinder whoich comes with a mirror mount will work, or will there not be enoungh fluid in it to make the brakes fuctional. |
Get a Yamaha FZR600 master. It's a very well built master cylinder and they are cheap to come by. I bought my last one for $5. I use them on everything.
http://www.duncandesignsstudio.com/justinsoddprojects/ |
I had this exact same problem with my Xkeleton and one day I went to sqeeze the front brake and the lever never returned and caused the front wheel to lock. I just used a spare front master from my Yamaha and it worked fine, just had to rewire the brake switch and all was good
Bikes: Yamaha 1974 Yz125a, Yamaha 1974 Sc500, Yamaha 1977 Rd400, Yamaha 1978 Yz125, 1988 Harley Davidson Xlh 883, 2006 Ktm 450 smr, Ekeleton 2006 Beast 200cc the worst bike I have ever owned |
If the slave locks up that's a different sort of problem...solution is the same, though. Replace the master.
In general, anyone who has disc brakes on one of these Chinese bikes I strongly suggest they replace the master cylinders. The calipers seem to be alright but all the banjo gaskets and the seals in the master cylinders are all garbage.
