06-12-2007, 09:43 PM | #16 |
Try contacting Meghan Sexton [meghan.sexton@bikealert.com] Below is what she quoted me. Otherwise check with Bruce @ EJCycles.
BIKE ALERT INC. 1465 Trae Lane Lithia Springs, GA 30122 770-948-8880 Phone 770-948-8893 Fax Performa Invoice Account #: Dealer & Retail Sales Nationwide Date: 05/24/07 Stock Code Qty $ Each TOTAL JTF259.17 1 $9.00 $9.00 UPS Ground $7.44 TOTAL AMOUNT $16.44 |
06-13-2007, 12:34 AM | #17 |
the jtf259.17 will not fit right..
...... the 520 sprocket that fits is this one note shaft size and here is the jtf259 JT does not seem to make a 428 sprocket that fits ...info i gatherd from the 520 conversion sticky... reason i was searching where to find the right one for 428 |
06-13-2007, 11:07 AM | #18 |
Understood. Is there anyway to grind, dremel 1/2 mm all the way around the sprocket axel? It's frustratingly close. :evil: Looked into a 520 conversion from 2 brick and mortor stores up here. Wow expensive. The chain alone was 50$ to 150$
06-13-2007, 12:23 PM | #19 |
17 tooth front sprocket
got my 17 tooth front sprocket and gold chain today and the sprocket fits so perfect on my roketa rds 200, it's not the sprocket for bigger motors its the one before that one just the plain 428 tooth
06-13-2007, 01:21 PM | #20 |
i got mine today took 3 days to get here.... fit nice but i did order the 17t tooth for larger motor... but i e-mailed him so maybe he just measured for me and sent the right one...i took it for a test run and its sweet at 45mph and goes 55 fairly easy
06-13-2007, 04:44 PM | #21 |
Good on ya man
06-14-2007, 08:02 AM | #22 |
Hey guys, here's the correct front sprocket from JT sprockets. 428 chain avaliable in 15 and 17 tooth. Fatboy, you can add it to the cross reference section.
http://www.jtsprockets.com/52.0.html...sel_uid=117&p=
06-14-2007, 08:37 AM | #23 | |
Jason
2008 Jonway MC-70-150 2007 Roketa DB-07B (RSM-200E) 2006 Roketa DB-07A (RSX-200E) 1995 Kawasaki Concours (ZG1000) |
06-14-2007, 04:51 PM | #24 |
thats some nice work i looked thru JT a bunch of times did'nt find it
