Old 08-01-2012, 06:55 PM   #1
Zombieking   Zombieking is offline
Lifan 200 GY-5 exhaust problem.
So... I broke of the top bolt that hold the exhaust to the engine, I used a hose ring to hold it closer but it is not complete air tight. Anyone know any way to fix this, or have any ideas?
Old 08-01-2012, 07:40 PM   #2
katoranger's Avatar
Remove the exhaust header. Get a vise grip on the little bit of bolt sticking out and remove the broken stud. Take a trip down to ACE hardware and get a new stud.
Old 08-01-2012, 08:11 PM   #3
Ok I tried but it is very hard, vise grips slip off
Old 08-01-2012, 09:30 PM   #4
I think I'm going to try heating it up and then removing it with vice grips on Friday, any suggestions before I try it?
Old 08-01-2012, 09:41 PM   #5
katoranger's Avatar
Heat around the bolt. You want the aluminum to expand. Wait for Weld to give some input too.
Old 08-01-2012, 09:45 PM   #6
Alright thanks, I was just going to heat the bolt.
Old 08-01-2012, 09:47 PM   #7
How hot do you think I should heat it?
Old 08-01-2012, 09:54 PM   #8
Also what would be the best kind of vice-grip to buy, Curved jaw, straight jaw or long nose?
Old 08-01-2012, 10:00 PM   #9
Wild_Alaskan   Wild_Alaskan is offline
Wild_Alaskan's Avatar
Heat around the bolt, if your using a propane torch don't worry about getting it too hot, its designed to dissipate heat.
some short nose non flat jawed vise-grips would be the best for that.
also what is the hose clamp on the exhaust for?
Dune buggy build http://chinariders.net/modules.php?n...wtopic&t=14470
400cc lifan build vid: http://youtu.be/20HoU8OK_Y0
other fun: http://tinyurl.com/wildalaskan
Old 08-01-2012, 10:06 PM   #10
Awesome thanks for the info, I will be using propane and ill buy a pair of curved jaw vice-grips.
Old 08-01-2012, 10:08 PM   #11
Should I try to pull it straight out or twist?
Old 08-01-2012, 10:08 PM   #12
whoops meant to say flat jawed would be the best
Old 08-01-2012, 10:09 PM   #13
Ok. Thanks for all the help by the way, greatly appreciated.
Old 08-01-2012, 10:09 PM   #14
unscrew it like a bolt, twist it counterclockwise.
Old 08-01-2012, 11:50 PM   #15
driller   driller is offline
Before heating it soak it with penetrating oil, clean off excess oil before heating and remember the first goal is to get some movement in the bolt, then unscrew so slight movement both clockwise and counter clockwise to "wiggle" the bolt loose sometimes works best.
