Old 08-02-2012, 12:57 AM   #16
Zombieking   Zombieking is offline
Alright, do you think WD-40 would do the job? Also how hot should I get it, Red hot?
Old 08-02-2012, 03:02 AM   #17
I recommend PB Blaster; it's an excellent penetrating oil. As long as you don't melt the aluminum, you will be fine. I replaced the studs with bolts on my Zongshen exhaust header.
Old 08-02-2012, 03:35 AM   #18
Wild_Alaskan   Wild_Alaskan is offline
Wild_Alaskan's Avatar
WD-40 is better than nothing, but as spud suggests pb blaster is much better.
The aluminum wont turn red when it is hot, just heat it about 1-2 mins while avoiding heating the bolt. you will need to get the vice grips on and turning quickly because the aluminum will cool rapidly.
Basically what you are trying to do is expand the aluminum more than the steel so the stud has a looser fit and allows you to break the bolt free.
Dune buggy build http://chinariders.net/modules.php?n...wtopic&t=14470
400cc lifan build vid: http://youtu.be/20HoU8OK_Y0
other fun: http://tinyurl.com/wildalaskan
Old 08-02-2012, 02:40 PM   #19
PBlaster is an excellent product, but it's designed to be used cold. If you need to heat the stud to remove it, get it as hot as you can (holding the flame on the stud), remove the heat and give it a quick shot of WD-40 around the perimeter of the stud.
The idea is to expand the stud with heat and then quickly quench it with WD-40. The stud immediately contracts and then the WD-40 wicks into the thread, usually allowing it to unscrew easily with whatever Vise Grips you have. Expect smoke when you spray WD-40 on the hot surface, and wear gloves and eye protection.
I've used this method for nasty rusted shock bolts on cars with good success.
Old 08-02-2012, 02:57 PM   #20
Wow! As always, thanks for posting the excellent advice, Weld.
In the future, I will reserve the PB Blaster for overnight soaking before I resort to the heat treatment you specified.
Old 08-02-2012, 02:59 PM   #21
katoranger's Avatar
That is an excellent tip.
Old 08-03-2012, 01:29 PM   #22
Alright I'm going to try it today, thanks for all the tips!
Old 08-03-2012, 03:41 PM   #23
WOOOOOooo, Turned out i didn't even need heat just a little wd-40 and a new pair of vice grips. Bought a 6mm stud and bolt. Now it's good as new. Thank you all for your help!
Old 08-03-2012, 03:48 PM   #24
Excellent! Glad to hear you got it sorted out, vice grips are handy beasty's!
Old 08-03-2012, 04:14 PM   #25
Git 'er done! 8)
Vise-Grips are one of the tools where the cheap knock-offs are not nearly as good as the real thing. I have MANY cheap Chinese tools but my Vise-Grips are the real thing. :wink:
Old 08-03-2012, 06:41 PM   #26
katoranger's Avatar
Originally Posted by FastDoc
Git 'er done! 8)
x2. Channel Locks too.
Old 08-03-2012, 06:50 PM   #27
Yes! That's another good example.
At the risk of diverting the thread more (but that's what we do :wink: ) I add to the list the Leatherman tool. Knockoffs are simply not as good. 8)
Old 08-04-2012, 12:40 AM   #28
driller   driller is offline
And the end all of tools the mighty Professional grade cordless drill. Yes it is worth $200 don't mess around with cheap drills trust me the good ones pay for themselves.
Old 08-04-2012, 01:54 AM   #29
katoranger's Avatar
I have been very happy with my craftsman drills.
Old 08-04-2012, 02:12 AM   #30
Good for you, ZK!
