egr valve
i took the hoses off my bike and it seems to run better. the hose that connects to the side of the motor , i started it up without it being plugged and it runs through the exaust but i crimped the tube and put it back on and it definetly has a lot more balls the throttle seems to be a lot touchier and i will probably get some more compression on my rds-200.
Yes...most of us have disabled or removed that system with good results.
2009 XR650L Big Red Pig Tusk bar risers 2007 X-Moto(Jetmoto) GY250 --mods--- 15/40 sprockets UNI Pod Filter 2007 Shineray TMS 200XYi--Betsy ![]() Betsy Mods:______________________ Acerbis DHH headlight FMF Powercore pipe Uni Pod Filter |
emissions
can any one tell me if taking this stuff of will actually help and do i leave the crankcase breather on ,but take everything else off
Leave the crankcase breather alone! Do Not plug it or remove it.
Thanks, Bruce @ Endless Journey Cycles "Phone Calls Only" ~330-274-0098~ Hours: Tue.-Fri. 10:00-6:00 Sat. 10:00-4:00 EST. Dealer for: Lifan, Crossrunner ATVs. http://www.endlessjourneycycles.net |
egr emissions
will i need to change the needle/clip height or carb setting ??? cause the burn on the plug was a perfect light tan before????I also cannot get any play in the clutch cable ,both adjustments are bottomed out ,bike is brand new will it get better.????
fishman
What make bike do you have? Yes you will need to re-adjust your carburetor, but I can't tell you what to re-adjust it to because I don't know where you live and what your altitude is. The clutch cable you have on the bike may be too short that's why you don't have any free-play. Will it get better... yes as the clutch plates wear but it may take quite a while. Your best bet is to get a longer clutch cable, but since I don't know what ends are on yours I can't help there would need pics.
egr
i have the orion or viva 250 dirtbike ,and now the seals on the upside down forks are leaking badly and of course no help from the internet site i bought it ,except to sell me new forks or sell me fork seals which are backordered from china, Bike is 3 days old.
#8 | |
Thanks,
Frostbite "The beatings will continue until moral improves" |
