Old 10-11-2013, 10:09 PM   #46
oviking99   oviking99 is offline
Size:  27.4 KBDonor, Longbo specs
Specifications: 1) Engine: LB253FMM, two cylinders, 4 stroke, air-cooled 2) Displacement: 233cc 3) Max. speed: 80km/h 4) Max. loading capacity: 150kg 5) Dimensions (L x W x H): 2300 x 850 x 1120mm 6) Rated power: 11.0kW/8500rpm 7) Dry gross weight: 140kg 8) Bore x stroke: 53.0 x 53.0mm 9) Min fuel consumption: 354g/kW.h 10) Wheelbase: 1480mm 11) Min. clearance: 130mm 12) Compress ratio: 9.2:1 13) Ignition: CDI 14) Clutch type: wet multi-plate 15) Starting mode: electrical / kick 16) Lubricating type: force splashing 17) Transmission system: international 5 gearshift 18) Transmission type: chain 19) Front brake: disc brake 20) Rear brake: drum 21) Fuel capacity: 11L 22) Rim type: aluminum 23) Headlight: 12V, 35 / 35W 24) Battery: 12V 7Ah 25) Front wheel: 110/90-16 26) Rear wheel: 130/90-15
Model No.: LB250-13
Product Origin: China
Brand Name: LONGBO
Old 10-11-2013, 11:01 PM   #47
Originally Posted by oviking99 View Post
Picked up the bike. LB253FMM, 2 cylinder. L for Lifan, 2 for 2 x 53 mm bore? I'm guessing.
2- 27mm carbs. This is all conjecture. It was a long drive thur Atl on Friday night traffic, then back. 4-1/2 hrs, with a stop at Jersey Mikes Deli. Incredible reubens BTW, but I am SURE glad I live in the country!! It is still on the trailer, she'll wait until the morn. Same size tires as the 200GY-2, 15 inch rear. It looks like a better dual sport than what's on the Vento. Almost new. 2,256 miles on the od, though that could be wrong. I'll post pics tomorrow. I hope the engine will fit the UM frame, as I have a title for it.
Do you plan to put better, off road tires on your Zong/Vento?
Old 10-11-2013, 11:30 PM   #48
Yes I do. The rear has maybe 30 % tread, but the front has slight dry rot causing it to oscillate at anything over 40mph. A bit scary entering a curve. I will replace the front soon, as it's much easier to find an 18" dual sport. The rear tire on the Longbo is the same size as the Zong. It's a Duro. The tread looks great, not quite dual sport. I'll post pics in the morning. I believe it was one of the tires mentioned in your tire thread.
Old 10-12-2013, 12:11 AM   #49
You have lots of good choices for the front wheel. The rear wheel is an entirely different matter.
Old 10-12-2013, 09:42 PM   #50
I posted the Duro rear tire pics in the Dual Sport Vento 200GY-2 section.
Old 10-12-2013, 11:23 PM   #51
You might be interested in this Duro 627 tire for sale on eBay.
http://www.ebay.com/itm/Dunlop-K627-...180661?vxp=mtr
You can also check if this vendor in Ontario can sell you a CST C7208 tire in size 130/90-15.
http://www.soslube.com/cst/tire-prod...ands/cst/c7208
Old 10-13-2013, 11:46 AM   #52
Great find. Thanks Spud! The sidewalls on the Dunlop looks like it will handle terrain much better than the Duro.
Old 10-13-2013, 02:11 PM   #53
You're welcome. I always enjoy the opportunity to help a fellow Zongite.
Old 10-13-2013, 10:03 PM   #54
2- 27mm carbs. This is all conjecture. It was a long drive thur Atl on Friday night traffic, then back. 4-1/2 hrs, with a stop at Jersey Mikes Deli. Incredible reubens BTW, but I am SURE glad I live in the country!! It is still on the trailer, she'll wait until the morn. Same size rear tire as the 200GY-2, 15 inch rear. It looks like a better dual sport than what's on the Vento. Almost new. 2,256 miles on the od, though that could be wrong. I'll post pics tomorrow. I hope the engine will fit the UM frame, as I have a title for it.
Awesome score! i wish we had stuff like that around here. The only road legal China bikes I've seen locally are 200cc DS Honda clones, and they're rare.
Mmm, reubens.
Old 10-15-2013, 08:02 PM   #55
The 75.00 Longbo donor.
Old 10-15-2013, 08:05 PM   #56
Old 10-15-2013, 09:40 PM   #57
Looks like good bobber material. At that price, you certainly wouldn't mind chopping it up.
Old 10-16-2013, 10:15 AM   #58
Most definitely. I think the seat on the kids Schwinn bicycle in the picture is higher!
Old 10-17-2013, 07:21 PM   #59
Posted the startup of the Longbo engine. Carb rebuild time.
Old 10-18-2013, 01:23 AM   #60
Dig the flames!
I presume that you're not going to run open exhaust, and the engine will smarten up considerably with mufflers. The carbs might not be as bad as you think.
