Old 04-14-2014, 11:42 PM   #1
flyfishinwoman   flyfishinwoman is offline
flyfishinwoman's Avatar
Saga 250 rear shock specs?
Hey all, new person with a question about lowering my Saga 250. I think the best solution is to get a replacement shock that is a bit shorter, so am trying to find out the specs of the stock rear shock, and find a replacement. I know the bike engine is a Honda cg125 copy, but not sure about the suspension. Anybody know? Thanks in advance.
Old 04-15-2014, 11:52 AM   #2
I'm prettty sure that the rear suspension uses a link, so fabricating a new dog bone could produce the seat height you seek. Have a look at the lower mount of the rear shock; does it mount directly to the swingarm, or does it attach to a link that passes through the swingarm?
If it uses a link, have a look underneath the bike. There should be a dogbone-shaped piece that connects the link to the frame. I think that a longer dogbone would lower the seat height.
Please take pics and show us what you find.
Old 04-15-2014, 11:42 PM   #3
Weld, you're right there is a dog-bone linkage, but I'm not sure that a longer bone would solve the problem due to the configuration of the linkage triangle. I'll have to take a better look and take a pic soon to figure out if that approach would work. Thanks for the suggestion, I'll get back and report what I find.
Old 04-16-2014, 12:02 AM   #4
If you could suspend the bike from overhead (like a tie down strap to a rafter), you could remove one bolt from the dogbone, and then lower the bike to where you'd like it. If the dogbone moves further away from the mounting point, a longer dogbone would lower the bike.
I would lower the forks in the triples a proportionate amount, so that the bike retains the same rake / trail / fork angle.
Old 04-16-2014, 08:16 PM   #5
That's a good idea to suspend from the ceiling. When you say lower the bike, do you mean let it down on the ground to the seat height that I require?
I will most definitely raise the forks in the triples to balance it out and keep the same geometry.
Thanks for your suggestion.
Old 04-17-2014, 12:47 AM   #6
Yes, sorry I didn't explain that well. I meant lower it with the ratchet tie-down, until it is at the height you wish. As you lower it, you can also loosen the triples and raise the forks. Perhaps before you begin, you can establish a point on the tank or seat that is level, and maintain that level as you lower the bike.
