Old 02-16-2015, 03:04 PM   #1
Sub Dude   Sub Dude is offline
Any info on a Hawk 250 dirt bike.
Just bought this Hawk 250 dirt bike in Arlington Texas and wanted to get more information about it. The bike is from the Chongqing Haosen manufacturing company and has a 167FMM 223CC engine. Is this manufacturer known for quality products, I found very little information about them? Are all of the 223cc Honda clone engines basically the same except for the side covers? I had the retailer replace the oil with synthetic oil and drove the 50 miles home then replaced the oil again. I found very little debris in the oil screen and the used oil was dark but nothing I did not expect. I put another 100 road miles on it the next day plus 5 off-road hill and sand miles. So far the only issue I have with the bike is it only will do 50 MPH and acts like it is starving for fuel or has a rev limiter kicking in. Lower speed but hard acceleration will also exhibit the same behavior. If the manual is to be believed the bike should do 60 MPH. I have not run it with the fuel cap removed to verify proper tank venting yet but wanted to hear other ideas of what I could check the next time I take it out. Thanks for your help.
Old 02-16-2015, 06:17 PM   #2
Nice looking bike! What year is it? It looks very much like my TMEC 200 enduro, but I am quite sure they are unrelated.
Old 02-16-2015, 06:23 PM   #3
Here is their Chinese site:
http://www.haosenmotor.com/
Old 02-16-2015, 08:34 PM   #4
katoranger's Avatar
I would suspect the carb is very lean from the factory. The other issue may be a giant rear sprocket.
Welcome. Have not seen that bike before.
Old 02-16-2015, 08:52 PM   #5
guttafixit   guttafixit is offline
guttafixit's Avatar
Thumbs Up
Nice bike. I like the looks of it.
Old 02-16-2015, 09:17 PM   #6
I don't know if you are a 'newbie' or not, but the choke lever on the carb should be all the way down. There are mornings, when the weather is cool (and when I first got my bike), I put the lever to half way to get her started and warming up, get the bike loaded with my lunch and such, start riding, and hit some nasty dead spots, and realize I had not put the choke back down. The ironic thing is, I wasn't even a newbie to my bike, a TMEC 200, since I had just owned an older model and should have known better!!
If that is not the case, it sounds like your bike could use some carb timing. As well, these bikes often come with awfully big rear sprockets which should be changed out, pronto. Most likely, you have a wheel which is a clone of a '80 Honda XR185 which makes sprocket shopping quite easy (and low cost!!).
Moderator 'Weldandgrind' has links to a continuous ebay seller who has Chinese Mikuni carbs...the advantage of changing out your carb to a Mikuni is the fact that the jets can be purchased most anywhere, whereas your stock carb is probably the decent (decent most of the time) Kiehen carb (which states PZ30 on it, and 'Standard of Japan') These are decent as stock carbs (I have not yet upgraded mine in the 4200 miles I have commuted on mine since the end of May) but their jets cannot be changed.
Stock, the bike should be able to hit 60 mph, and with a rear sprocket change, it should be able to maintain (cruise at) 60 or up to 65 without sounding like the engine is screaming for mercy.
Old 02-17-2015, 12:39 AM   #7
Welcome!
X2 on the lean carb and the big sprocket.
Old 02-17-2015, 12:40 AM   #8
How did you determine the engine is 223?
Old 02-17-2015, 01:59 AM   #9
Welcome; we are glad you joined us.
X3 on the large rear sprocket.
Old 02-17-2015, 02:00 AM   #10
Thanks culcune, the bike was manufactured in 2014.
Old 02-17-2015, 02:17 AM   #11
Yes, I was worried about the choke position because the manual did not show what position was closed or open. I found some pictures on the site of my PZ30 carb which cleared up the confusion. I had been running the choke in the correct position. When I bought the bike the dealer was concerned about me filling up the fuel tank all the way due to not having enough air in the tank to draw fuel, so that is my next issue to investigate. When the bike is at 50 MPH you can feel the bike miss or hesitate. If the venting is not the problem I will look into getting a Mikuni carb.
Old 02-17-2015, 02:21 AM   #12
223cc is incorrect I should have stated that it is a 229cc engine which is printed on the emission control tag on the engine.
Old 02-17-2015, 08:25 AM   #13
alex_in_az   alex_in_az is online now
nice looking bike, X4 on the sprocket and carb mods
2020 Tao TBR7
9.3:1 PnP head
CRF230F exhaust
4 degree advance key
290 degree cam
Nibbi PE30 and cone filter
Front fork brace
Old 02-17-2015, 11:06 AM   #14
Here's a good deal on a Mikuni: http://www.ebay.com/itm/30MM-MIKUNI-...ab812e&vxp=mtr
Old 02-17-2015, 01:57 PM   #15
Thanks Weldandgrind, that does look like a good deal. Do the motorcycles normally have a rev limiter installed? I may have to strap-on a tach to see if the engine is even getting close to red line when I lose power.
