Old 05-09-2015, 12:06 AM   #46
If you don't change anything other than the size of the rear sprocket, you will need to remove 4 links from the drive chain.
Old 05-09-2015, 12:04 PM   #47
Originally Posted by midlifemx5 View Post
I have put a few more miles on my bike. Had a little spill off road so it's got an imperfection... So I don't have to worry about that any more. I am going to install a 45 tooth sprocket as soon as I find the time. The gearing is a bit too low for how we are using the bikes. Anyone know if or how much I would have to shorten the chain? (Going from a 52 to a 45 tooth sprocket) Also I have developed an oil leak that I have narrowed to the shift shaft seal. Any suggestions on where I should look to get a new one? Does anyone know if a Honda / Yamaha one would work? Part #or application would be a big help. Thanks in advance!
Good for you for knocking the shine off; now you can enjoy it.
The shifter seal is likely to be the same as a Honda XR200, but you can likely just take the numbers off of the seal and get a replacement at a local bearing shop.
Old 05-09-2015, 07:15 PM   #48
midlifemx5   midlifemx5 is offline
Thanks Spud! I have another question for you or possibly Weldangrind. I ordered a new Mukuni carb today (The one that is recommended on here so much) I am going to free up the exhaust by gutting the cat, and I have a uni foam filter to go in the slightly modified stock air box
(I opened up the intake holes about double the original size) I operate primarily at 5000 - 8000 ft above sea level, where would you recommend I start with the jetting, with these conditions in mind?_
P.S. this is a 229cc engine
Old 05-09-2015, 07:24 PM   #49
Thanks Weld, upon taking a really good hard look at the oil leak today I found the oil level to be about a 1/2 quart too high, after correcting this the oil leak seems to have been eliminated. Ill keep an eye on it, and report back. (I feel stupid)
Old 05-09-2015, 09:07 PM   #50
I defer to Weldangrind, who is the resident, Mikuni carburetor expert.
Old 05-10-2015, 11:03 AM   #51
We've all done it.
Even if the seal doesn't heal itself, it's not a big deal to replace.
Old 05-10-2015, 11:05 AM   #52
Can engines even run at that elevation?
I'd start with a 115 main and a 30 slow. If it won't start despite adjusting the pilot mixture screw, go to a 27.5 slow.
Old 05-10-2015, 11:06 AM   #53
I'll accept enthusiast, but I'm no expert.
Old 05-10-2015, 04:46 PM   #54
Thanks for the starting point. I'll put in an order for some jets to get started with. BTW I see that there are 2 different styles of slow (pilot jets) for the vm series carb which ones does the carb in your link take?
Old 05-10-2015, 05:48 PM   #55
Maybe a better question is what series# is this Carburetor, I'm pretty sure it's a VM, but what is the sub series # I cant really tell for sure from your comparison photos which type of slow jet to order. Sorry for all the questions you have probably had to answer before
Old 05-11-2015, 12:49 AM   #56
IIRC, the China 30mm Mikuni takes a VM28 / 486 style slow jet.
Old 05-11-2015, 12:53 AM   #57
Please don't hesitate to ask questions! I love hanging out in this shop, and I'm happy to contribute whatever I can. Thanks for joining us.
Old 05-11-2015, 01:00 PM   #58
Thanks so much the help is much appreciated!
Old 05-15-2015, 11:11 PM   #59
I got the carb and jets today! I don't think I will get them installed tomorrow but I will post a report when I do.
Old 05-16-2015, 01:48 PM   #60
Awesome! I hope it works out well for you.
