If you remove the rear wheel, you will have easy access to all the bolts, except one. You cannot remove the top, swingarm bolt of the rocker, because it is blocked by the chain slider. Remove the Allen head bolt which holds the chain slider to the bottom of the swingarm, and you can move the chain slider out of the way to remove this bolt from the rocker/knuckle/arm.
![]() When I re-assembled the lower shock linkage, I inserted this bolt from the right side. Therefore, I won't need to mess with the chain slider next time. ![]()
