Still chasing the Hawk Gremlins....
Thank you all for this site. I have been able to make a lot of progress on fine tuning the two Hawks I bought. One of them, mine of course, is still giving me two troubles and hopefully I can get some insight;
- The front shocks make a lot of noise at full extension. When I hit the bumps at some speed it sounds like the front end will fall off. I have replaced the fork oil with an equal amount of synthetic ATF but no improvement. - At start up I have no power. Bike starts fine with choke and quickly idles. But until it is warm, 5-6 minutes, I have zero power. It acts like a 30 cc pit bike. Once warm it runs great. Thanks again for any response. I am pretty handy with repairs but new to motorcycles. For some reason my wife's bike runs perfectly! |
Let me start with saying I know nothing about your bikes specificly. I don't know if you have any sort of maintenance manual for your bikes, either.
Doug, you're in an excellent position compared to other folks, having 2 identical machines with one of them running good. I suggest putting your wife's carb on your bike and see if the power/running problem goes away. Immediately return her carb!!!!! It may be as simple as idle mixture needing adjustment, or may be dirt in the jet(s). Investigate. I also suggest you check the valve clearance on your engine, hers as well. Replacing the oil in the forks with the same amount assumes the quantity was correct to begin with. I suggest trying to find out what amount is supposed to be in them. Good luck. |
#3 | |
Brandon 2014 Hawk 250 Firehawk minibike Previous bikes~ 1995 Yamaha YZ125 1998 Yamaha YZ250 1981 Yamaha YZ465 1987 Honda TRX 250R X2 one stock one modified 2002 Buell Blast 2001 Buell X1 Lightning 2000 Kawasaki ZR7 |
Thanks guys. I like the carb stealing solution! I know we have a dealer rep in our group. I will ask him for the fork oil volume. Just odd that the power comes back to my bike so quickly. Will keep you posted.
I'm going with valve adjust also. The forks? Sounds like you're topping out. Possibly overfilled??
Thanks 2LZ. I could do as Jay suggested on the carb and drain the wife's fork oil and measure. I used the same 2/3 of a cup in each of my shocks that I removed. I rarely bottom out but they make a terrible noise when they are suddenly fully extended, topping out.
#7 | |
Like heck if I can find where I wrote all this stuff down when I did all my forks. That's the problem with moving! My vital records end up on Oak Island.
Did the valve job, thanks for all the info. However that did not make a bit of difference. I think for $40 I might just order new carb.
It might make you happy.
If your front end sounds like its about to come apart its probably the steering stem. mine was not torqued right from the factory and i almost lost my top nut. get it on a stand, pull your handlebars and your upper triple clamp and tighten that castle nut until its tight. I used slip joint pliers, if it becomes hard to turn the forks you went to far. put it all back together using loctite and proper torque specs. that front end chatter should be gone. now you can listen to your brake pads chatter.
Check out my Hawk 250 Motovlog Channel https://www.youtube.com/channel/UCUU...JoVrsuhnV-7Zkw |
Oh wow you weren't kidding. It was only finger tight. I tightened it up tonight and will have to see if the helps. Thanks!
