Old 03-10-2016, 11:36 PM   #16
hnu13   hnu13 is offline
That looks pretty cool. A supermoto front fender will really complete the look.
if you look closely, you can see the sharpie line for fender cut. Haha. lol
Old 03-13-2016, 10:01 AM   #17
chuck   chuck is offline
Hi hnu13,did your ninja rims come with the brake rotors??
Old 03-13-2016, 09:39 PM   #18
midlifemx5   midlifemx5 is offline
Originally Posted by TXDSRIDER View Post
What did you use to remove the hawk text from your seat brake cleaner?
Acetone took it off of mine really easy just be careful to use it sparingly.
Old 03-14-2016, 02:54 AM   #19
paulesmann   paulesmann is offline
paulesmann's Avatar
More pics bruh
Paul Mann
2015 Haosen Hawk
1989 Kawasaki EX500
1991 Suzuki DR350
Old 03-16-2016, 01:03 PM   #20
Yes they did...
Old 03-17-2016, 12:37 PM   #21
Thanks.
Old 05-19-2017, 08:58 PM   #22
enforcer89   enforcer89 is offline
I really like it can you post spacer specs and such
Old 05-20-2017, 06:09 AM   #23
bogieboy's Avatar
When i did my converaion with the 86 ninja wheels on my roketa, the rear used the stock spacers and the front i used the speedo hub in its normal spot and just stacked 1/2 washers til the forks didnt bind and the brakes didn't rub... Its really not a hard conversion... I made it harder by using the 86 rims that used a larger rear brake rotor though...LOL had to cut down a 1/4" off of it to fit my rear caliper...
Old 02-21-2018, 11:15 PM   #24
Peter802   Peter802 is offline
I have a bashan enforcer . What would be the ideal supermoto conversion for this bike ?
Old 03-24-2018, 12:20 AM   #25
yoonit1   yoonit1 is offline
I see this thread has died a while ago but just picked up some ninja 250 wheels and ready to get this going. I will try to document everything and put pictures up so others can know how to do this. Hopefully it will be a success!
Old 03-24-2018, 11:02 AM   #26
bogieboy's Avatar
some day when i have spare time i will try and rehost my threads pics...LOL
Old 03-25-2018, 08:58 PM   #27
would be better to upload to this site so they dont disappear like that
2016 hawk
kaw h1 400 tripple
13' long chopper in progress
2009 johnny pag bar hog
Old 04-07-2018, 04:03 PM   #28
Ok so the back wheels fits really well, but you will have to change the front sprocket for 520 chain. The sprocket is a JT sprocket, jtf.328. The spacer that came with the wheel lines up with the sprockets
The main problem is the brake bracket, the rotor bolts will hit it, so you will need to get the ninja 250 rear brake bracket and rear brake, I'm waiting on that to come in but I'm 99% sure it'll work.
I took the rear brake off and drove it around and everything else seems good, but you will need a smaller rear sprocket.
As for the front it's gonna take a bit more work, only did an initial fit up so don't have much info on the front
Old 04-07-2018, 08:41 PM   #29
bogieboy's Avatar
Interesting... i didnt have issues with the rotor bolts hitting anything on my 86 250 wheels.... as for sprockets, i have a 12t front currently, and 38t rear on my rims....
Old 05-11-2019, 09:25 PM   #30
Alaskaalaska   Alaskaalaska is offline
I started this project as well based on OPs recommendation of the ninja wheels, and I've done a similar project using ninja wheels on a klr650 that didn't end very well. Things look MUCH brighter for this bike. Here's my video on it, and I'll be updating as I go.
