Old 04-05-2016, 08:31 AM   #7
Originally Posted by Haggis View Post
Priced at $3 I don't think that is needle bearings?
This is the same drawing also used by ajp and gasgas and looks like the sleeve that would run inside the bronze bush.
Wonder why some have a proper bearing while some have a bush?
4rvid, can you give measurements for your bronze bush please.
Does the bronze bush run directly on the gearbox input shaft?
Or is there a spacer/sleeve that's fits over the shaft first that the bronze bush would run on?
You're welcome.
That is why I suggested you contact them for information.
Our RX3 bikes should have the needle bearings, and CSC should carry them as replacement parts. If this is the case, the parts diagram is inaccurate, and CSC will stock the needle bearings, with a different price. However, CSC will still need to know the part number to check their inventory. Nevertheless, I haven't pulled the clutch basket, so I can't verify my conjecture. That's why you need to contact CSC, and talk to them.
