Old 06-10-2016, 05:06 AM   #1
Joyrider   Joyrider is offline
Lexmoto Assault oil and filter change
Hi there, I wondered if anyone could help me please. Im going to perform the first service on my bike (300 miles) Ive bought the oil, spark plug but the oil filter is whats called an oil strainer but Ive no idea where it fits, any ideas please, Thanks, Phil
Old 06-10-2016, 05:16 AM   #2
pete   pete is offline
pete's Avatar
Also known as a Aprila ETX150....
oil strainer is in side the motor... normaly just wash them in petrol..
if it's a round tube it comes out with the oil drain plug... "easy"
Also a biggish spring in there...
if it's a flat screen it's in side the right "clutch" case.... "not so easy"
Now I am asumming these motors are a Honda copy.....
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 06-10-2016, 06:46 AM   #3
humanbeing's Avatar
http://www.chinariders.net/showpost....61&postcount=3
http://www.lexmoto.co.uk/HJ125-J.php | WMI:LD3 http://www.tayomotor.com
62mm kit https://item.taobao.com/item.htm?id=40902941761 can direct fits...
Old 06-10-2016, 08:21 AM   #4
dpl096   dpl096 is offline
dpl096's Avatar
Sporty looking bike ! Im curious what its happy spot is for cruising down the road?
― Thomas Jefferson
Old 06-10-2016, 09:21 AM   #5
Thanks for the info Guys, I think the motor is a Suzuki GS125 copy. The oil strainer looks like a metal gauze thimble so will it be on the end of the sump plug? otherwise I might have to order a gasket if Ive got to take an engine cover off. The speed of the bike is about 60-65mph. Ive only done 300 miles up to now but its loosening up all the time. Engine very tight when I first got it. Phil
Old 06-10-2016, 09:33 AM   #6
humanbeing's Avatar
...I think the motor is a Suzuki GS125 copy...
Inspired by Honda design... Engine supplied by Tayo's subsidiary http://www.tyanmotor.com/
Old 06-10-2016, 09:12 PM   #7
pete's Avatar
by the sounds of it you will find it on the drain plug...
if it is a Honda copy you will need a 24mm socket as
it is on the side of the sump below the fly wheel cover..
heres a link to a chinarides thread on the Aprila ETX150
looks like your bike...
======> http://www.chinariders.net/showthread.php?t=16664
09 XT660R ...
06 TTR250 ...
81 Honda CT110...
Old 06-10-2016, 10:55 PM   #8
humanbeing's Avatar
Old 06-16-2016, 04:04 AM   #9
Did the servicing yesterday and everything went to plan, I was trying to richen it up a bit. Theres a mixture screw on the front of the carb behind the cylinder, quite difficult to get to, but it hasnt made much difference. Its always run on the lean side since Ive had it, to start from cold you need the choke full on and keep revving it for at least 3 minutes before it will settle down and tick over. Anyway, thanks guys for info youve all given me. Phil
Old 06-16-2016, 10:56 AM   #10
Phil, it sounds like you could benefit from a larger slow jet in the carb.
Old 06-18-2016, 02:06 PM   #11
Thanks for that info Weldangrind, I'll have a look and see what size jet is fitted as standard then oe up, Phil
Old 06-18-2016, 10:52 PM   #12
humanbeing's Avatar
Deni CPZ26? In these newer 国Ⅲ (similar to Euro 3) http://wenku.baidu.com/view/24edb9fe...eaeaa31de.html needle is unadjustable...
General guide: http://translate.google.com/translat...tml&edit-text=
Old 06-21-2016, 09:21 AM   #13
Yes that looks like the one humanbeing, Thanks
