Good news. The TT is "getting better" but is still hard to find when hot. I'm hoping as the miles and oil changes happen, it will get much easier.
everybike I have ever had ...
XR70 CR125R CR250R R6 all were hard to find neutral ... maybe this bike it worse but a trick i found was to tap the shifter instead of trying to go super easy |
My brother's is quite easier to get into neutral on his Hawk, but mine as it get's hot is almost impossible. It may make a huge difference with an oil change though. I'm gonna try to run some really good GN4 oil in it and see if it helps when I do the oil change.
after riding my hawk i get what your saying but try this .... when your in 2ed gear just tap the shifter down ... use your foot like a impack gun just tap and once you get used too it you will find N real easy
My speedometer quit working at 20 miles and the odometer followed at 30 miles, but at what I estimated to be 50 miles l changed the oil to conventional Valvoline 10w-40 4 stroke motorcycle oil, because I was not able to find neutral at all with the engine running and I figured it couldn't hurt to try.
The only way I could get it into neutral was with the engine off. I was getting false neutral indications too, which concerned me. I tried the light tap down from second. I tried everything. The oil change seems to have done the trick. I can actually find neutral relatively easily now. If I could get a working speedometer and odometer, I would be really satisfied with this bike.
2016 CSC TT250 |
I'm going to.
2016 CSC TT250 |
#8 | |
The light tap approach that has been mentioned for finding neutral works well for me. |
Yeah, the only problem is the guy has to buy 100 up front and there may not be enough interest for him to fork out the cash.
2016 CSC TT250 |
#10 | |
I'll get them ordered tonight. I think their is enough interest and as word gets out their will be more. The accurate speedo is a HUGE plus as well as the gear indicator and the low fuel light..... |
#11 | |
2016 CSC TT250 |
