Another new arrival Sunny Duel Sport 250
http://countyimports.com/i/u/6023538...t_bike_i3.jpeg
http://countyimports.com/inc/sdetail...--/45335/22312 The sunny dual sport
I must be blind. I can't seem to find the page with it on it on their site. Can you post a link?
2016 CSC TT250 |
That's been around a while it's a Dongfang DF250RTE-B. It has a Zong engine.
Here are some better pics http://www.scooterfolks.com/DB_D250R...-d250rte-b.htm http://df-motor.com/product_show.asp?id=696 |
Blinged up re-badged Hawk with street tires (or is the Hawk an unblinged Sunny with kobbies?)
To me if they get over the $1600 ranges you might as well go with CSC TT!
They all share very similar attributes and generally are very similar. As almost all china dual sports will use 1 of 2 engines honda clone engines. There are always exceptions to this rule. The big differences are in quality from the manufactures. Haosen manufactures both the hawk and the hawk's engine. Where as the Dongfang uses a Zongshen engine that is epa certified for street use. In china supply chain is everything so typically vertical integration produces a better product but if you have good suppliers ( like Zongshen) then that is not always the case. The TT is still going to be almost $2500 out the door.
#7 | |
Yup....for many years, a Hondoid was a Hondoid was a Hondoid. Haosen (Hensim) has always made a "nicer" version of a Hondoid, along with Zong. Lifan was the standard bearer, solid Hondoid for quite a while. Now the Hawk and CSC TT250 have once again elevated the bar on the Hondoid dramatically. Very nice pieces, both of them. The only breakaways were the Zong Sierra (Yamaha) and the Konker/Qlink/SSR (Suzuki). Both of these have always been of a noticeably higher grade and quality than your Hondoid of old.
The major lacking point of these motors on the bikes are the absolute weak amount of horsepower. They should focus a bit more on building the bike to put out 20-22 horsepower. I know they don't want to spend a ton on research and development, but a motor that could actually move and do a rolling speed wheelie would be a much better selling point. Even if it required the motors to need to be liquid cooled or to be honest, they could switch to fuel injection for better power.
#9 | |
2016 CSC TT250 |
#11 | |
![]() Hey 2lz, do you see what I see on that engine, sells for $2200 wonder if it's true.
#13 |
That kinda does look like an OHV doesn't it? Engine is a 165FMM which would mean it's has an OHV.
#14 |
Wise guy mode on.
A word about OHV. It means overhead valves. the expression is usually used in conjunction with the layout as a pushrod engine. The camshaft or shafts are placed within or slightly elevated in the crankcase. The Engine pictured is clearly an OHC, as in overhead camshaft. The valves however, are placed just the same way "overhead". anyway, in this configuration it is called OHC. ...wise guy mode off. :-)
Je suis Paris, je suis Europe ! Liberte Egalite Fraternite ! Last edited by Panic-Pete; 08-07-2016 at 01:11 PM. |
#15 | |
Look at that rear sprocket. Typical Hondoid, geared to climb a telephone pole! LOL!
