Old 08-08-2016, 10:53 AM   #1
jerickw   jerickw is offline
nibbi carb
does anyone have any experience with this carb https://www.amazon.com/dp/B01CYKGO9Y?psc=1
it looks to be of great quality and easy to jet would it fit a zongshen 250? any other carb suggestions if this isnt worth it?
Old 08-08-2016, 11:04 AM   #2
That does look like a really nice setup! Nice machine work. I have that same Nibbi air filter and am very happy with the quality. Flat slides are supposed to be good, not sure why though. It says flat slide but it looks round???
My only concern is it's rather spendy. You can get a Mikuni and that air filter for less than half the cost and they work very well...and jetting is abundant.
Any idea where to get jets and for what model carb?
Edit: Ok...I see some of the kits come with 4 jets.
Old 08-08-2016, 12:19 PM   #3
Ariel Red Hunter's Avatar
Did you look at the comments section? Problems . . . .
Old 08-08-2016, 12:35 PM   #4
That's definitely a round slide, and it appears to be a two-stroke carb. It has an air screw rather than a fuel screw, and it's on the wrong end of the carb.
Old 08-08-2016, 12:41 PM   #5
yeah i saw that but it doesnt have enough review not sure if a fluke or not and looking at other sites and reviews people seem to like it just a little pricy i just want a carb that isnt to hard to jet since in my state between summer and late fall ill need jets from 105-115 likely
Old 08-08-2016, 11:41 PM   #6
nonone   nonone is offline
Nibbi is suppose to be good I don't have any hands on experience with them as I typically opt for Keihin or Mikuni. I don't believe Nibbi does any real R&D all though some say they do just like OKO and KOSO. I seen a PE 28 listed as semi flat side (half moon) though it defiantly does not look like a flat side. Not sure if it's true. I've seen some PE series described as "4 stroke special" but have no idea if this is true or not. The listing does say CG so you might be okay. Worse case they ship you a 2 stroke carb.
If it is in fact a 4 stoke carb it's probably a Frankenstein so parts and jets maybe difficult to find from anyone else but Nibbi. Although I would suspect it would be part Keihin PE and PZ.
http://www.keihincarbs.com/carbs/pe/gate.html
Here is a PE28 clone for reference http://www.ebay.com/itm/252336767414
Old 08-09-2016, 02:48 AM   #7
pete   pete is offline
pete's Avatar
Get a Koso flat slide carb call it a nibbi put a few bling bits on it
and add $60 to the prise......
why not go to alliexspess and buy the un-blinged version
for a 1/3 of the prise..
I imagine they are pulling the same with the round slide in your link...
I have a OKO flat slide 26mm on my 1977 Montesa cota 348 trials bike
& a Koso 32mm flat slide on my Yamaha TTR250..
the "flat slide" is in fact a D slide...best of a round & flat slide...
Main and Pilot jets are on alliexspress for 10 jets of your choice
for around $10 per 10....
32mm KOSO D slide power jet on my Yamaha TTR250... they work well....
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 08-09-2016, 06:57 AM   #8
I would suggest that a Mikuni VM 26 for about $30.00 is a good match for you. Jets, slides, needles - virtually everything is available for these carbs, and without breaking the bank to get 'em, either.
Old 08-09-2016, 11:54 AM   #9
I'm having a heck of a time locating a replacement idle mixture screw for my VM 26 knockoff. Everything else is no problem though.
Old 08-09-2016, 02:59 PM   #10
I found one for a Mikuni vm 26 on e-bay. Item number 191539860297.
Old 08-09-2016, 04:57 PM   #11
no, that's an idle screw, not idle mixture.
Old 08-09-2016, 07:02 PM   #12
Bruce's   Bruce's is offline
Just buy another $20.00 carb ,rob the screw from it and save the rest for a rainy day .
Old 08-09-2016, 08:17 PM   #13
Are you looking for the Air Screw? Part # VM20/214.
www.ebay.com/itm/172119470734
Or one of the variations there quite possibly could be others
http://www.aliexpress.com/store/product/Free-shipping-2PCS-fuel-ratio-adjusting-screw-Motorcycle-carburetor-Mikuni-the-carb-air-screw-For/1540211_32597630286.html
http://www.aliexpress.com/store/prod...633161488.html
At ~$10 your better off buying another carb like Bruce said. Extra parts always come in handy.
Here is some good info for VM's
http://www.vintagesnow.com/Carbureto...s/vmmanual.pdf
Old 08-09-2016, 10:31 PM   #14
ok thanks for the help everyone i think im going to go with an oko flat slide carb anyone have an amazon link or ebay link to one with the adapter to run on a zongshen 250(same exact mounting points as a lifan 200)?
Old 08-09-2016, 10:33 PM   #15
and forgot to add wold need jetting too prob between 105-115 ive read they come super out of tune with jets that are much higher then they should be. anyone have any experience with these is this true?
