Old 08-22-2016, 07:21 PM   #1
PNWDualRider   PNWDualRider is offline
PNWDualRider's Avatar
TT250 Drive Chain
Hey guys,
So I'm having to tighten my drive chain like every 75km, is this chain just stretching a ton? I'm thinking of just getting a new chain but I don't know where to start. I'd like to get a high quality chain and not a cheap-o. Thanks for the help in advance.
*2016 CSC TT250
*2006 Zongshen ZS200GY-2
*1973 Honda SL100
Old 08-22-2016, 07:35 PM   #2
Ariel Red Hunter's Avatar
Originally Posted by PNWDualRider View Post
Hey guys,
I reccomend Unibear chain. It is pre-stretched at the factory, and the guys using it are having good service out of it. It only costs about 13 dollars and is of very high quality. Keep it clean and lubricated and it will last a long time
Old 08-22-2016, 08:45 PM   #3
'16 TT250   '16 TT250 is offline
When I read posts like this it's usually because the guy is trying to keep the chain too tight. Make sure you're adjusting to spec and tightening the axle to spec.
Old 08-23-2016, 01:59 AM   #4
I have the chain exactly to spec so I must need to tighten down the axel a bit more. I've heard some horror stories about the chain breaking while going up a steep climb and having to walk the bike back to the truck. I would just rather get a new one now.
Do you know what size of chain will work best for this bike?
*2016 CSC TT250
*1973 Honda SL100
Old 08-23-2016, 11:13 AM   #5
As ARH recommended, get one of these. I'm sold. The original chain was horrible.
Old 08-23-2016, 12:21 PM   #6
I just bought one. Thanks for the Unibear tip, guys.
Old 08-23-2016, 12:35 PM   #7
You'll like it. Weld. Out of box, each link was buttery smooth and is peened at 12, 3, 6, and 9. It runs silently on Mrs. 2LZ TT.
Old 08-23-2016, 03:41 PM   #8
Darkrider   Darkrider is offline
Bookmarked that link to get a chain for the XL185
Past bikes:
'10 Gio X33
'85 Honda VF750F Interceptor
'80 Honda XL185S
'76 Yamaha DT250C dual sport
Baja Wilderness Trail 250
'07 Honda Shadow 750 Areo Trike
'01 Harley Davidson Softail Deuce
Polaris Magnum 425 4x4
Originally Posted by andyj812 View Post
You can't pin this one on me, my wife is still mad at me. I don't need your wife mad at me too. LOL
Disclaimer: The above post by 2LZ is in no way the view of this site, other members or Bruce's llama. It is the opinion of 2LZ and 2LZ alone. ;-)
Old 08-29-2016, 08:26 AM   #9
motopat   motopat is offline
I just bought one of the unibear chains you guys are recommending too. For $20.00 I'd rather place a new one on, based on all the good reviews. As are some of the mechanical things on this bike, replacing the chain will be a new one for me. Can anyone suggest proper chain replacement tools?
Old 08-29-2016, 10:25 AM   #10
Azhule   Azhule is offline
You will probably need a "Chain Breaker"
http://www.harborfreight.com/heavy-d...ker-66488.html
and something to cut/grind the rivets down a bit before you use the "Chain Breaker"... of course that's only if you need to remove any links in the chain
The video they change out a 520 O-Ring chain, the 428 chain on these China Bikes are a little easier to change out then a O-Ring 520 Chain
Old 09-03-2016, 10:23 PM   #11
Doh!
Purchased the Amazin chain that was recommended and after I broke my original chain, the new one is 2 links too short...
*2016 CSC TT250
*1973 Honda SL100
Old 09-04-2016, 12:39 AM   #12
hertz9753's Avatar
Add a couple of master links. Not that I have ever done that...
Old 09-04-2016, 01:43 AM   #13
use a smaller rear sprocket
Old 09-04-2016, 02:23 AM   #14
I wanna keep the original sprockets for more torque for trails. I bought 130 link chain. Should be here 9/8/16.
*2016 CSC TT250
*1973 Honda SL100
Old 09-04-2016, 07:41 AM   #15
Rats! I bought a 128 link chain too, based on a recommendation here. Looks like I'll count links before I cut, but I have the same bike as PNW so I too will probably need one with 130 links. I'll report back. Maybe the 128 link chain fits on the TT bikes that came with the 15 tooth front sproctet. Ok, the new Unibear 128 has--you guessed it--128 links. The TT has 130 links, like PNW said. So, did you guys who fit a 128 on make it fit by adjusting the wheel forward? Or that in conjunction with smaller sprockets? Also, I'll mention that the owners manual says the original chain must be cut off when it needs to be replaced. The manual says that it has no master link. Mine has a master link. That will make it simpler to change, just "daisy chain" the new one in. I'm new at chains. Is there 2 links of adjustment with the wheel adjusters?
