09-23-2016, 08:53 AM | #1 |
top end rebuild how often?
hello guys i have a 2006 gy-2 style cg 200 with a zongshen 250 that i converted to a enduro style dirtbike. my question is with pure dirt use how often do i need to rebuild the motor with these chinese motors? I never really go above third gear but i spend alot of time at high rpm's. i was just gonna do the standard 150 hours that id do with a ktm or honda but was not sure if its more or less often since this does hold more oil then a dirt bike
thanks in advanced! |
09-23-2016, 08:57 AM | #2 | |
09-23-2016, 08:59 AM | #3 |
the the air cooled zongshen 250 and it is a pushrod style
09-23-2016, 09:08 AM | #4 |
heres just a picture of the bike mid ride yesterday still runs great good compression as of now at least just pops alot since i cant find the exhaust gasket for the point that it connects to the motor
09-23-2016, 09:38 AM | #5 |
The pushrod engine is one of the longest lived little engines ever built. It was originally designed to operate in absolutely abysmal conditions. A good air cleaner, and thousand mile oil changes will make this engine run a very long time. So will valve clearance check-ups. If you don't have a speedometer, 1000 miles is about 30 hours at an average speed of thirty-five miles per hour. As long as the cylinder compression is good, the engine is good to go. The copper o-ring for the Honda 230 fits, and is much better than the original head pipe gasket that comes with these little hummers.
09-23-2016, 09:44 AM | #6 | |
09-23-2016, 10:03 AM | #7 |
As ARH states, a dang long time , especially if maintained. It's not like the good-ol'-days where you had to do a bore, piston and rings every two season on your 2 stroke.
09-23-2016, 10:15 AM | #8 | |
09-23-2016, 10:23 AM | #9 | |
09-23-2016, 10:35 AM | #10 |
CG engines have a centrifugal oil filter under the clutch cover, attached to the crankshaft. It does a good job at trapping the fine particles. Quick and easy to clean once the clutch cover is removed.
09-23-2016, 11:05 AM | #11 |
The stock screen is identical to what is used in the Honda XR200 OHC motor. It works fine as long as it is cleaned every 10 hours or so.
09-23-2016, 11:34 AM | #12 |
Sometimes it's tight, but you can usually get the valve cover off without lowering the engine. Sometimes people will trim or grind away a bit of the valve cover fins to make valve cover removal possible / easier.
09-23-2016, 12:28 PM | #13 |
Thank you for that info. I didn't know that. I'll remember it, though.
09-23-2016, 12:47 PM | #14 |
ok thanks for the info ill have to see about grinding it down next time a remove it because ive tried taking it off before while on the bike just didnt have the clearance hopefully doing that will let it slip off
09-23-2016, 01:37 PM | #15 |
On some bikes the valve cover will clear the frame if the rocker arms are in a certain position. If it almost comes out, try rotating the crankshaft and see if there is a spot where you can wiggle it out.
