Hello friends i am writing this message in turkey. I have my 2016 model zhongsen rx3 motorcycle. Sold by mondial in my country. The ear found on the top cover of my motocross cracked. The motorcycle is leaking oil. 10 000 km. Having the same problem that a lot of motorcycle road. The master recommended welding instead of replacing parts. Aluminum is said to be more robust with welding. Do you have such a problem? If so, how did you find a solution? I use google translation. I hope I did not write wrong. Good day.
https://drive.google.com/file/d/0B17...ew?usp=sharing Last edited by ayna639; 12-19-2016 at 09:52 AM. Reason: picture |
Hi! I dont understand the problem, or where on the motorcycle it is. Maybe some pictures would help. Someone here should be able to assist you.
I added a photo link.The problem is here. Motor oil comes from here
https://drive.google.com/file/d/0B17...ew?usp=sharing |
I don't know the answer. It looks cast as part of the entire engine, so welding would seem to be the only solution to the problem. Someone else will be along here to help you soon. Is the crack on the top, near the gas tank, or the bottom part, closest to the engine?
Hi ayna639,
There have been others with a similar problem but as far as I know not in the USA or UK You can find a little about it here http://www.chinariders.net/showthrea...t=crack&page=9 posts #133 to #138 As AdventureDad has already said, a bit of welding or a replacement part will be the only fix. But you might find some of the ideas in the above thread might help to stop it happening again. ![]() |
#6 | |
2016 CSC RX3 Silver |
The part on CSC's website is $160. Use the Coupon Code NEWYEAR for 20% off until the end of the year. Not sure what shipping to Turkey would be.
http://www.cscmotorcycles.com/PART-1...-p/z10-110.htm Alternately, if I'm reading the recommendation in Katflap's link, the fix is to remove the bolt going thru the mounting point in the cylinder head assembly. Since it's no longer weight bearing/supporting, some quick steel or jb weld epoxy could be used to fill the crack and stop the leak. Just a thought. Rojo
'15 RX3 (Rojo's) '15 RX3 (marzhere's) '16 TT250 |
I've used JB Weld 2 part epoxy to fix small cracks and holes in my engine cases before. rj
Live Zong, and Prosper |
İs here, fixed
https://drive.google.com/file/d/0B17...w?usp=drivesdk https://drive.google.com/file/d/0B17...w?usp=drivesdk https://drive.google.com/file/d/0B17...w?usp=drivesdk |
