Old 03-22-2017, 10:30 PM   #16
ughmas   ughmas is offline
ughmas's Avatar
I'll have to check out the manual again. Both our TT and my neighbors hates finding neutral, when stopped, when it's hot and they're both beyond the 500 break-in with fresh 15W-40 Rotella. Both have the cables adjusted to where there's very little freeplay in the lever.
service manual specifies 1/4 to 1/2 inch of freeplay in the clutch lever if I remember correct
2005 CBR600RR
2016 CSC TT250 Coming Soon
Old 03-22-2017, 10:44 PM   #17
you will be turning it off to find neutral at those settings.
2016 hawk
kaw h1 400 tripple
13' long chopper in progress
2009 johnny pag bar hog
Old 03-23-2017, 10:18 AM   #18
I think I have mine set at about 1/8"-1/4". Basically, it's as little as possible without the clutch slipping under hard acceleration. Even my RX3's don't like to find neutral when hot and running at a stop. Q slips right in no problem. I'm just hoping it cleans up with miles.
Old 03-23-2017, 10:22 AM   #19
Sullybiker   Sullybiker is offline
Sullybiker's Avatar
I suspect I get a lot of practice as I can feel it through my foot, but you inevitably get good at something if you spend an hour a day at it...
I'll be interested to see what it's like when summer gets to full bore and I'm in traffic. Even my Ninja's buttery smooth shifting starts to get lumpy in the heat.
Old 03-23-2017, 12:36 PM   #20
RogerWFarrier   RogerWFarrier is offline
RogerWFarrier's Avatar
On page 32 of the manual it says to adjust the cable slack with the engine‐mounted adjusters until there is approximately 3 mm of slack on the handlebar clutch lever. This is what I went by when I adjusted my clutch. Once I set it to 3 mm slack in the cable I fine tuned it with the barrel adjuster with the engine warm until it would slip in an out of neutral easily. It took a little fiddling but I haven't had any issues finding neutral since.
Old 03-24-2017, 04:06 PM   #21
Biker_Andy   Biker_Andy is offline
Biker_Andy's Avatar
Interesting, I've never needed to adjust my clutch yet so I guess mine must be disengaging properly for now. I will keep that in mind if neutral becomes elusive.
Old 03-24-2017, 05:13 PM   #22
Manual!? LOL!
I'll have to check this out. I'm going to be working on my neighbor's TT also. Thanks........
Old 03-24-2017, 06:28 PM   #23
hertz9753's Avatar
http://therps.net/User%20Manual/Hawk...s%20Manual.pdf
That is the Hawk manual.
Old 03-28-2017, 11:57 AM   #24
wilserchinarider   wilserchinarider is offline
I also had trouble finding neutral on the Hawk. Finally I tightened the clutch cable to the point of zero free play and neutral selection is greatly improved. My guess is that the collection of chinese parts don't interact as they should and the clutch lever on the engine case is not being rotated quite enough, or slightly less than the ideal amount. "Over Tightening" the clutch cable seems to cure this issue. Of course be aware that clutch slippage should be avoided!!!
Old 03-28-2017, 02:01 PM   #25
kohburn   kohburn is offline
kohburn's Avatar
Originally Posted by Biker_Andy View Post
The electric start works wonderfully so unfortunately I have no experience starting her with the kick start. I've been meaning to try it out just to see how easy or not she kicks but haven't got around to it. She under cover until spring atm.
my original battery died a horrible death but I was still able to kick over the tt250 no problem with it half choked - the headlight flashed with the rpm at idle, but it ran fine. new battery being installed this week.
-whatever you do, just be awesome.
- 2008 Kawasaki Versys
- 2016 CSC TT250
Old 03-28-2017, 02:09 PM   #26
So far, no problem with the stock battery but I've had it on a trickler all Winter. Hopefully there will be no horrible death any time soon.
Old 03-28-2017, 02:44 PM   #27
kohburn's Avatar
mine dried out sitting for 3 months. I tried topping it off and putting on the charger over night but it cooked out a lot of the water. I may give it another try but in the mean time I picked up a sealed glass mat battery to use instead.
- 2016 CSC TT250
Old 03-29-2017, 09:37 PM   #28
Biker_Andy's Avatar
Fired my TT up yesterday. It was bogging when giving higher throttle and died whenever I tried to take it off half choke. Rode it to gas station and put new gas in it and drained the old gas out of the float bowl. I Might try adding some sea foam directly to the bowl if problem persists. Hopefully it was just bad gas but I have doubts. Bike would only run with choke on even after it was warmed up but the temperature was only barely above freezing. It supposed to be nicer tomorrow so hopefully I can get her going. She's parked in a heated garage now so hopefully she will run without the choke tomorrow. She ran so wonderfully before I parked her for the winter.
Old 03-30-2017, 04:59 PM   #29
Biker_Andy's Avatar
I feel like an idiot. I was operating the choke backwards. No wonder the bike kept dieing when I tried to take it off half choke! Bike starts and runs as good as new.
Old 03-31-2017, 02:56 AM   #30
we have all been there at least once!
2016 hawk
kaw h1 400 tripple
