Old 03-27-2017, 10:09 PM   #1
Slaphappy   Slaphappy is offline
New Rhino 250 owner/member
Just finished assembling my new Rhino but haven't been able to ride it other than in my yard. Working a lot and waiting on the paperwork to register it.
I have been reading this board for a few weeks and it looks like it is going to be my main source of info on this machine. It already helped knowing what to expect when the pallet arrived. Manual is worthless and the CD isn't even a good table coaster... knowing that before I got it was a good thing because I did some checking around on how to assemble it.
Now I chose this particular brand because the price is ridiculously cheap. My father is getting up there in age and I really wanted to have an ATV so we could ride at our camp before he isn't able to do it anymore. So this thing is going to be a casual rider for me.. 90% of it on seasonal gravel/dirt roads. I may put a hitch on it to tow a small 4x8 utility trailer to use in the yard...maybe. I say I am going to do a lot of things and never do it. We shall see.
I have a question. I have done the break in thing. Changed the oil with 15/40 and put locktite on the bolts I installed.
I'm not concerned with performance or speed right now. I pretty much just want a machine that will ride dependably on dirt roads. What should I do to it? I'm thinking of just getting a new chain for the stock sprockets a more robust battery and riding it until something pops up. Hopefully not 20 miles from home.
At some point I may want to mod it up a little but my mechanical experience/know how is pretty limited and I don't want to experiment on it when it is brand new. Anything need immediate lubing besides the chain?
I found the best way to start it is to use full choke..start it and let it stall and then turn choke off and use the throttle to idle it until it warms up. Once it warms up it actually runs pretty good.
The paperwork that did come with it said the manufacture date was in 2013. Wow..
Thanks to anyone who takes the time to read that.
Old 03-27-2017, 11:21 PM   #2
Widowmaker   Widowmaker is offline
Welcome to the Rhino Club! I think the 37 tooth rear sprocket is a mod that should be done by any Rhino owner. The stock gear ratio is way to high, unless you just want to go fast.
Old 03-27-2017, 11:32 PM   #3
I may do the sprocket after reading about it and the difference it makes. Speed isn't something I am super worried about so maybe I will do it sooner rather than later. I may also change the carb sooner than I thought.
My concern is taking things apart and taking forever to get it back together right. My dad is already chomping at the bit to plan a ride and I've only had it for a week.
Old 03-27-2017, 11:36 PM   #4
My other motivation is ..every person I told that I bought a Chinese ATV looked at me like I was bananas. My brothers friend even mocked me. He didn't even know there was such a thing. I think he will be surprised when he sees it. It isn't terrible for the price. I just want to make sure it doesn't break down on the first ride..
I'm going to maintain this thing like it cost me $400,000.
Old 03-28-2017, 12:32 AM   #5
If I may ask...Did you keep the front sprocket original? And do you remember where you got the 37 tooth sprocket? And what chain did you end up with?
Old 03-28-2017, 01:10 PM   #6
justjoe001   justjoe001 is offline
I bought this kit on ebay for like $136. Comes with 37 tooth front and 11 tooth rear and 530 chain.
Taotao Rhino 250 200 Front Sprocket 11 Tooth 530 Counter T 11T Kit 37 Tooth Rear
Old 03-28-2017, 03:24 PM   #7
One stop shopping. Thanks!
Old 03-28-2017, 04:27 PM   #8
I maintain all of my rolling stock as you said in your last sentence. Whether it cost me 5.00 or 5000.00, mechanical things need a little love.
You'll get callused to the China Bike doubters and hecklers. Bottom line is, they're either completely ignorant, only trust "their brand" or end up buying one after they see/ride yours. It's always the same after they pull up on it. "This only cost HOW MUCH!?"
My neighbor, who had ZERO trust in Chinese goods, to the point of making fun of my stock, bought a TT250 after he rode my wife's.
Old 03-29-2017, 12:37 AM   #9
I believe that last part. I know they will change their opinion once they see it...especially after I mod it up a little. I was going to ride this stock for a little bit but after going through some of these threads I don't think I want to wait anymore.
If I had to pick between sprocket/chain mod or new carb what would be better? Open question to anyone actually. I need a new roof this spring and would like to get that out of the way before getting too deep.
Old 03-29-2017, 10:02 AM   #10
If the carb runs good enough at your elevation, I wouldn't worry about it. If you're not going to be towing or hauling anything slow, the stock gearing should be ok for you.
I drag a cart around the property and never leave first gear so the gearing was important to me. I needed slow speed pulling power more than fun trail riding speed.
Regarding the engine mods, I did them all because for one, I can't leave well-enough-alone ands two, the carb was definitely not working right for me.....plus I had an extra FMF Turbine Core 2 laying around so it was begging to be mounted.
Old 03-29-2017, 12:52 PM   #11
I'm going to copy your hitch design though. I doubt I would ever haul more than a few hundred pounds with it. Everything just seems to work so darn good out of the box right now. It's a little cranky until it warms up but so am I.
When things slow down mid summer I know I will get the itch to do something.. especially if I keep reading this board. Thanks for the reply.
Old 03-29-2017, 08:30 PM   #12
Was able to hook up the trailer I use with the lawn tractor to the Rhino. Went around my 4 acres picking up branches that came down in a bad wind storm a few weeks ago. So much faster and easier than using the mower. And more fun.
Then I picked my way through the woods for a bit on a joy ride... even more fun!
I think my favorite thing about this ATV is its simplicity and I can get my hands in there to work on things.
Old 03-29-2017, 09:05 PM   #13
Darth Racer's Avatar
If it all worked good for you the first upgrade I would shoot for is a Mikuni or Mikuni Clone carb... will give your more horsepower and a more responsive engine.
Sounds like you don't need lower torqued sprockets.. the extra oomph from the carb upgrade will just make it all better. If anything you will then have a carb you can open up when things get all gummed up and be able to get it working again.
Old 03-29-2017, 10:27 PM   #14
Makes sense to me. Fairly cheap too. Have to admit I'm a little intimidated by the tuning part of it. Probably won't be as bad as I am imagining.
Discovered a problem I hadn't thought of until a little while ago. My 15 x 25 foot shed is getting cramped. Snowmobile, tractor, snowblower, tool cart and work bench required me to do chess moves to get the stuff out I wanted to use. Throw the Rhino in there and it has become more of a choreographed dance. Sweating to the oldies kinda thing. Could have worse problems I suppose.
Old 03-30-2017, 10:07 AM   #15
Swampy   Swampy is offline
Swampy's Avatar
Time for another shed!
1986 TT350, 2002 Grizzly 660, 2009 TR125 and two 2015 Kandi 150cc Quads.
