Old 04-23-2017, 08:37 PM   #1
aaron7   aaron7 is offline
What model Baja Motorsports ATV is this???
No one has been able to identify this thing... hoping someone here can!
Older ATV made by Baja Motorsports. VIN comes up as a 2005.
I did check their site, they don't list anything like this.
Trying to find the model so I can locate at least a new petcock and a front right brake cable.
Every part on it says NATIONAL MOTOR on it.
The motor stamping behind the shifter is NM637259
The VIN on the frame is RKKGCKLCX5B637259
Any ideas?
Old 04-23-2017, 11:32 PM   #2
Adjuster's Avatar
Road hard and put away wet. That thing is dangerous as is. Although that would never stop me.
Old 04-24-2017, 06:14 AM   #3
Sure is! I rewired it and put that new coil on, she's a runner!
Of course, the idle climbs by itself, it has no brakes, no kill switch, and is sketchy as hell.
All part of the challenge!
Going to make it ridable with a end-of-the-world-mad-max sorta theme.
Old 04-24-2017, 07:25 AM   #4
humanbeing's Avatar
Model: X150 https://hub.gardnerinc.com/customer_..._BREAKDOWN.pdf
RKK = Taiwan http://datagovtw.com/company.php?id=22003706 |http://xinglxm.diytrade.com/sdp/687897/3/home/0.html
Compare by the shape & measurement & find something that fits
Typical petcock https://shop107992121.taobao.com/category-863472330.htm
Old 04-24-2017, 11:48 AM   #5
Great, thanks for the identify! I've emailed Baja with the new information and hoping they still have exploded diagrams of this model.
As for the petcock, yes, I'll pull it and just start comparing on ebay!
Old 04-24-2017, 11:51 AM   #6
Appears it may be this one, I'll check more when I get home
http://www.ebay.com/itm/182218069900
Old 04-24-2017, 04:17 PM   #7
humanbeing's Avatar
Originally Posted by aaron7 View Post
... hoping they still have exploded diagrams of this model...
http://www.jmcmotors.us/bajaparts/ma...IX%20RKKG).pdf
R. CRANKCOVER ASSEMBLY #12 had a oil filter ie. a Frankenstein that wants some Suzuki blood (16510-05240/ KN-131...)
Measurements of that Suzi: https://item.taobao.com/item.htm?id=530585143577
Old 04-26-2017, 09:39 AM   #8
You're awesome, thanks for the link!
Now one last thing... where I might be able to find some of the less-universal parts.
The exhaust studs are snapped off. I don't know if I can remove them or not. Odds of finding a jug are pretty much zero I'd imagine, right?
Old 04-26-2017, 05:07 PM   #9
humanbeing's Avatar
...Odds of finding a jug are pretty much zero I'd imagine, right?
Hopefully those = Typical chinese CG150 that based on Kymco 150 http://blog.xuite.net/tsai.kevin36/scooter/27916748 ... not the good old small-fin Honda https://translate.google.com/transla...3D1&edit-text=
http://translate.baiducontent.com/tr...en=&monLang=zh | http://www.motorfans.com.cn/forum.ph...uthorid=290040
Old 04-26-2017, 06:15 PM   #10
Mudflap   Mudflap is offline
If you can get your hands on a mig welder, set a nut over the broken stud and weld the nut to the stud from the inside then unscrew it. Works nearly every time.
Old 04-26-2017, 09:07 PM   #11
Use anti seize going back with replacements
I bet you could find the bolts at a place like Fastenal https://www.fastenal.com/
Or similar bolt speciality
Old 04-26-2017, 10:57 PM   #12
humanbeing's Avatar
It's either M6 https://item.taobao.com/item.htm?id=15023169968 (the pdf said M6*35) or M8 https://item.taobao.com/item.htm?id=42510987721 . Took it out as #11 said & measures it...
Old 04-28-2017, 08:48 AM   #13
Originally Posted by humanbeing View Post
Hmm, doesn't quite appear the same. I'll have to do some more digging!
Definitely a good method! But the issue here is the studs have snapped inside the holes... no way to weld down in there. MIGHT get lucky drilling and easyoutting... but probably not.
Excellent! At least I have a lead on replacements if I can ever get these out.
Old 04-28-2017, 08:49 AM   #14
Do need a front left brake pull cable too. Bet you know right where to get one!
