Old 12-03-2015, 06:20 PM   #16
rjmorel   rjmorel is offline
rjmorel's Avatar
sales@dobeckperformance.com,
neither link working, I think it's because of the comma, period on the end ???? rj
Live Zong, and Prosper
Old 12-03-2015, 07:18 PM   #17
rtking   rtking is offline
It works for me, but it inserts the address into my default email account. It may be easier to just copy and paste into the "To" line in your email.
I sent an email to request more info / timing. Great to hear that they're interested!
Old 12-03-2015, 11:02 PM   #18
Originally Posted by rtking View Post
It works for me, but it inserts the address into my default email account. It may be easier to just copy and paste into the "To" line in your email...
Indeed, that's probably the best solution. However, I did edit his post to erase the period. Try the link again, and see if it works.
Old 12-10-2015, 05:20 PM   #19
I'm bumping this thread back to the top. If you guys are interested in an EJK controller for the RX3's fuel system, please send an email to sales@dobeckperformance.com, and let them know.
Old 04-26-2017, 08:15 AM   #20
AdAn82   AdAn82 is offline
Bump
Any further info on this, Spud?
Adrian
2016 CSC RX3
2015 TaoTao 50
2006 GSX-R 600 (retired)
"If the world didn't suck, we'd all fall off"
Old 04-26-2017, 11:24 AM   #21
Originally Posted by AdAn82 View Post
Bump
No, I don't have anything new to report. I think the fuel map in the Delphi MT05 ECU is performing pretty well, so there seems to be little interest from most RX3 owners to seek an aftermarket fix.
Old 05-03-2017, 12:22 AM   #22
pete   pete is offline
pete's Avatar
Originally Posted by SpudRider View Post
I talked to Matt this morning, and asked him about the missing O2 sensor. He said the AJP PR5 operates well with the EJK box alone, and does not need the O2 sensor.
some questions to think about...
#1 - What stops the ECU looking for the signal from the O2 sencer if it's removed?
#2 - Have they managed to reprogramme/flash the ECU so it turns a blind eye to not having some of the info it is programmed to use......
#3 - The O2 sencer is what lets the ECU know what the AF ratio is , So where is this info now coming from ?..
Heaps of these things all over the net in verying degrees of nasty....
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 05-03-2017, 01:09 AM   #23
ChondaChondaChonda   ChondaChondaChonda is offline
ChondaChondaChonda's Avatar
To be fair, many EFI systems will remove the typical "narrow band" sensor because they are designed to target 14.7:1 Air/Fuel ratios. 14.7:1 is great for efficiency, but for all out power the target Air/Fuel ratio needs to be richer.
For this reason there are many EFI systems that will not have an O2 sensor. Wide band sensors are expensive and finicky. The Honda/Kawasaki/KTM off road bikes all use systems that do not have O2 sensors.
Some of the ECM's I have tuned do allow you to select the range and time delay for the O2 sensor to kick in; on my old bike you could have the O2 sensor affect only the highway cruise part of the map, but it then adjusted the fuel calculations for the entire map. For all out HP on the same bike the O2 probe could be disabled.
1993 CR125 powered by Zongshen 223cc OHC
2̶0̶1̶6̶ ̶L̶X̶R̶ ̶2̶5̶0̶ ̶E̶F̶I̶ ̶ Sold
2018 GPX Moto FSE250R
1993 Fantic Key-Roo 250
Old 05-03-2017, 03:10 AM   #24
pete's Avatar
the bikes you are quoteing never had them so the ECU was not programmed
to look for info from a O2 sencer....
but if it did have then was removed ?... there must be a gap in
the info the ECU is receiving....
my XT660R has 2 AF ratios...open & closed loop..
in short one for cruse & a richer one for accelerating..
I have a A/F control but still has the O2 sencer...
09 XT660R ...
06 TTR250 ...
81 Honda CT110...
