Old 05-17-2017, 03:10 PM   #1
Shortlegrider   Shortlegrider is offline
just ordered a magician 250
after much research a second thoughts I finally pulled the trigger on ordering a magician 250. I know the hawk is probably a better off road bike but I am a short legged dude. I ordered it from txpowersports and I hope this goes smoothly. thanks to all of you guys on this forum, reading your posts have helped me to get a Chinese bike.
Old 05-17-2017, 03:37 PM   #2
Merlin   Merlin is offline
Hi welcome to the forum.
Bashan Blaze
Mods: Alloy Rim's, Muffler, Mukuni VM26 Carb, Foam Filter, Tachometer, Volt Meter,LED Headlight, LED Blinkers
Old 05-17-2017, 03:51 PM   #3
ben2go   ben2go is offline
Good luck. Pics upon arrival or it never happened.
Old 05-17-2017, 07:25 PM   #4
Did you make sure the bike can be registered? It, like the Hawk, is certified as an 'off-road motorcycle' according to the EPA, although it seems that well over half the states will plate the Hawk (which would include the Magician, by default, since both are on the same certificate). If you are good to go, congrats!!
Old 05-17-2017, 09:33 PM   #5
dpl096   dpl096 is offline
dpl096's Avatar
Welcome aboard indeed! Pics are a requirement for the satisfaction of all. . . . yes yes yes it's CB porn but who cares
― Thomas Jefferson
Old 05-17-2017, 10:01 PM   #6
Jarwolf   Jarwolf is offline
Jarwolf's Avatar
@shortlegrider, Good luck man! I got it from there fully assembled, had to out front tire on, mirrors, handle bars, muffler, as well as pull out the battery to place the acid in there, fender had to be out on as well. For some reason, the bike will not start for several attempts. When it finally starts, it makes an odd sound on the back tire. I can't seem to even move the bike without the engine on. I put it in nutral and the back tire seems like it is locked up. Also, the seat wont open up the storage area. If you have these problems solved, PLEASE let me know the solutions.
Old 05-17-2017, 10:48 PM   #7
Did you happen to check and align the rear wheel? Being hard to move in neutral sounds like a mechanical bind and the sprockets may not be lined up or the chain is catching/rubbing on the tire.
Also, if you got the bike as you describe, it wasnt fully assembled. Fully assemled means all of those parts would have been installed already.
Old 05-17-2017, 10:56 PM   #8
pistolclass's Avatar
Hey shortlegrider. Congrats on you purchase. I think nh is fine with hawk or magician. Where about in NH? I bought a place in Dalton in February. Hopefully I will start to build next year.
Old 05-18-2017, 01:58 AM   #9
Jarwolf's Avatar
Indeed, it came in a crate like that, the back tire was already on there, it must be their problem. My father left out a small clear silicone looking tube. Does that have anything to do with it?
Old 05-18-2017, 04:27 AM   #10
no the tube goes on the battery
2016 hawk
kaw h1 400 tripple
13' long chopper in progress
2009 johnny pag bar hog
Old 05-18-2017, 06:57 AM   #11
Sir kayakalot   Sir kayakalot is offline
Sir kayakalot's Avatar
Congrats shortleg! Pics as soon as you get it then pics during un-crating and after final assembly, that's the only way to properly thank everyone for helping you to decide on a China bike! Good luck and have fun with it. Make sure EVERY moving part is properly greased before you ride.
Hawk 250 Mikuni carb 115 main. De-catted pipe. Air box mod. 15/42 sprockets. Digital instrument cluster, FMF end cap on muffler, handlebar toolbag, Custom foot pegs
Old 05-18-2017, 08:36 AM   #12
I live in Sanbornville (wakefield as the locals call it) its near Wolfeboro. hope you enjoy the north woods
Old 05-18-2017, 08:42 AM   #13
nh is pretty good about registering dirtbikes, I had a klx300 that I applied for a tittle and got a plate for. its pretty easy to do, our state motto is " LIVE FREE OR DIE"
Old 05-18-2017, 08:51 AM   #14
If the engine is cold you will need to use the choke. Check to make sure your chain is aliened and is not rubbing the tire. Brake is probably locked up. More than likely the rear brake pedal needs adjusting. And most important Chain the oil that came in it. Read the manual if provided. It has all this information in it. Link to manual if you don't have one. http://therps.net/Magician.html
Old 05-18-2017, 03:56 PM   #15
just got my tracking #
