#31 | ||
I think the 46 rear is a good starting point for what you want. It will put you right at 3.07. Then, if you want to go a little taller, try a 16 front, shorter then your 14 front. Going in either direction wouldn't require changing the chain links either as it's only a +1 or -1 front. That would give you a 2.88 and a 3.29 respectively. That's why I suggested the rear first.
#32 | |
#33 |
same thing a little cheaper. http://www.ebay.com/itm/252822244650...84.m1436.l2649
would these fit the oem shenway carb on the hawks?
#34 | |
I was wondering the same thing.
#35 |
yep they fit the mikuni carb, and so much easier to adjust
http://www.chinariders.net/showthrea...180#post255180 |
#36 |
but will they fit the oem shenway?
#37 |
So ordering the sprocket was a little more than I thought it would be. All the sellers were in Europe lol, finally found on on eBay, 45T. Can't wait to get it on and see the difference it makes.
2005 Kazuma Cheetah 200 (Swamp Thing) |
#38 |
Well I got the Mikuni on and what a difference, bike runs so much better. Smoother acceleration, no break up what an improvement.
Next I have to swap out the sprockets and see how she does on the road with the better gearing for street use. And yes I got rid of the choke cable, that little flipper on the carb is in perfect position to just reach under and adjust.
#39 |
Totally agree the Mikuni upgrade was a great improvement on my hawk (110 pilot).
#41 |
I kept the stock 15T front sprocket and changed to a 45T rear. I like it so far.
#42 | |
![]() Rides a 2016 Bashan 18C with Blue PlastiDip, piped and jetted, USB charger, real-time digital volt meter, faux carbon fiber handguards, 5 COB led headlight upgrade, auxiliary led light bars, and an MSR shift lever with new grips, T6 aluminum handlebars anodized in blue, polished handlebar brace, decals, HD Unibear chain and spoke covers waiting on the always-full mod shelf...... |
#43 | |
