08-25-2017, 03:42 PM | #1 |
smog blockoff plate for cg250 emissions plug
Where can I get a plate to cover the hole where the emissions control system comes off the cylinder head? Apparently it's a thing u can get for bikes but idk where to get one for a cg250 engine.
08-25-2017, 04:21 PM | #2 |
I don't think you will find one. Most on here just fabricate one out of steel or aluminum.
08-25-2017, 08:27 PM | #5 |
How far apart are the bolts on these? Would this work? http://www.ebay.com/itm/311298248082
It looks similar. I have a piece of hose with a bolt in one end that's hose clamped on to it but it looks like shit. I don't wanna jury rig it. |
08-25-2017, 09:09 PM | #6 |
Evap block off plate, from Cleveland Cycle werks.
$14.95 but not currently available. |
08-25-2017, 09:10 PM | #7 |
Block off plate.
That's alot of money for something you can make for free,,,,just trace the plate you took off including the bolt holes,, transfer that to a piece of metal. An cut it out .
2015 zongshen rx3,,(Sold),,,2016 bashan storm,,2005 Harley ultra classic. |
08-25-2017, 09:28 PM | #8 |
Well I don't really have metal I can use lying around.
08-25-2017, 09:35 PM | #9 |
Block off plate
You only need a very small piece ,,guarantee if you trace it on to paper an show it to a garage or welding or machine shop ,,, they will probably give you a small scrap piece,,
08-25-2017, 09:45 PM | #10 |
Here is a link to what I used
https://smile.amazon.com/Dorman-Help-41050-Vacuum-Asst/dp/B000COB5TE/ref=pd_sbs_263_9?_encoding=UTF8&psc=1&refRID=WCBRB 3KNV68Q2SY08PVS I also took a tie wrap and used it to tighten it down a clamp would also work.
2016 Brozz Last edited by goat67; 08-26-2017 at 04:40 PM. |
09-26-2019, 04:03 PM | #11 |
I know this is an old thread but I was searching for a plate too. I would suggest that if you use a vacuum cap you also shove some folded up/rolled up aluminum foil down into the "J-shaped" pipe before putting the cap on it. I would imagine hot exhaust will eventually melt or ruin the rubber...
09-26-2019, 04:22 PM | #12 |
keep it all china syndrome!!!!! my mrs commandeered the steel off of our crate to build a project!!!
09-26-2019, 05:22 PM | #13 |
BaShan BSR 250 DB-41H 2018 Red BS250GY-18D JFG Racing Exhaust . Adjustable Shock 320mm . Brozz Digital Gauge . Renthal Fat Bar . 428 17x46 Sprocket . Fender Eliminator . Wheel Truing . Fuel Tank Repair . Keihin PZ30 Main-115 Pilot-38 Needle-1Washer Fuel Mixture-1/2 BSR Chronicles - "Project leads to more projects!" Yamaha WR250R Suzuki GSX-R 600 |
09-26-2019, 07:45 PM | #14 |
Just curious what the advantage is to removing the whole assembly and blocking it off? Does it hurt anything to keep it connected?
09-26-2019, 09:32 PM | #15 |
Its worth removing if you change the exhaust or decat the factory system. Unless you like hearing pops, bangs, and spitting flames and burning out any muffler packing hou might have.
