Old 05-19-2017, 11:51 AM   #16
rvl8rida   rvl8rida is offline
so the fact that i have mine on the lowest notch with a washer under it probably means im too rich? haha
Old 05-19-2017, 11:59 AM   #17
I think that says you probably want to consider going up a size or two on the main jet.
Old 05-19-2017, 01:13 PM   #18
Ariel Red Hunter's Avatar
I agree!!...ARH
Old 07-05-2017, 08:27 AM   #19
Wancsta   Wancsta is offline
Bike: 2015 RPS Hawk
Elevation: 1100ft
Carb: PZ30
Jet sizes: 110 main, stock pilot
Needle setting: 2 shims
Pilot screw turns: 2.25
Relevant mods: Air box mod, foam filter element, eBay exhaust, 17t front, 47t rear, shinko 705'
Top speed: 67(gps) flat out, can cruise at 60 now
Old 07-07-2017, 11:27 PM   #20
RogerWFarrier   RogerWFarrier is offline
RogerWFarrier's Avatar
The stock carbs don't have the grooves so we have to shim it.
The TT runs a Keima carb from the factory and it does have the slotted needle so it's just a matter of moving the clip to change needle position.
2016 CSC TT 250, 17/40 sprockets, JT 428 chain, Stock Keima carburetor with needle raised 1 notch and 115 main jet. Modified stock exhaust, Tachometer/Digital cluster upgrade. LED headlight, Superbrightleds 1157 Tail light bulb, Shinko 705's 90/90-21 and 120/80-18.
Old 07-08-2017, 08:10 AM   #21
Sullybiker   Sullybiker is offline
Sullybiker's Avatar
TT250. Altitude 1000ft.
VM26 Chikuni, stock exhaust and airbox.
Pilot: 27
Main: 105
Mixture screw 1.75 turns out.
Old 07-11-2017, 06:36 AM   #22
jimwildman   jimwildman is offline
jimwildman's Avatar
Originally Posted by Ariel Red Hunter View Post
I didn't know that an Ariel Square Four was wierdo stuff, but I am always willing to be educated. Sorry you didn't find any useful stuff on Hawk Talk...ARH
so now your gonna ruin this thread too?
Old 07-11-2017, 09:43 AM   #23
If you don't like what I write - don't read it...ARH
Old 07-16-2017, 02:49 AM   #24
Revised.
Bike: 2017 Hawk
Elevation: 1100ft
Carb: Mikuni VM26 "30mm" Clone
Jet sizes: Genuine Mikuni Jets - 27.5 Pilot. 117.5 Main, factory needle and needle jet.
Needle setting: 4th notch down from the top. (center also works, but I chose the "fatter" option)
Pilot screw turns: 1 1/4 (still needs a little fine tuning but close)
Relevant mods: Sprockets - 17 front, 43 rear. Uni pod filter, Ebay exhaust. Denso iridium plug, NGK XD05F plug cap with resistor removed and shortened plug wire.
Top speed: 70mph GPS on flat ground wth no wind.
Old 07-29-2017, 10:59 PM   #25
Bumping this thread so people are aware of it. Don't be afraid to post examples on here for others. With so many Mikuni clones out there, I think there could be a few more examples on here.
Old 08-01-2017, 10:06 PM   #26
silva   silva is offline
silva's Avatar
Doh! hawk 250
Bike: 2016 hawk. .
Elevation: 6400
Carb: PZ30 98 main/stock pilot. Relevant mods: k&n air filter/box mod .Ebay exhaust. NGK BR8EIX plug.
Rotella T6. Valve cover oil cooler from mjstef.
JT non o-ring chain. 17/40 gearing. shinko 705 (rear) Top speed:75 mph, (gps)
Old 08-01-2017, 10:54 PM   #27
pistolclass's Avatar
2016 hawk:
$30 Makuni (fake) VM26
110 main
20 pilot
2 turns out
needle set on fattest setting.
Stock Air box
Stock exhaust
63 mph top speed
15 front
50 rear
set both intake and Exhaust to 0.05 mm
matt's digital cluster
MSR shifter
burrito tube
Hawk starts right up and there is no flat spot in the RPM range. Really happy with this set up.
Old 08-06-2017, 09:08 PM   #28
KingPrimusIII   KingPrimusIII is offline
KingPrimusIII's Avatar
Bike: 2015 Hawk
Elevation:240'
Carb: Factory
Jet sizes: 110 Kehein main, factory pilot
Needle setting: 2 custom washers
Pilot screw turns: 1 1/2
Relevant mods: Airbox mod, NGK plug
Top speed: 57mph, gps confirmed
"You think life is crazy now? Just wait until the internet arrives!" -Albert Einstein
Old 09-13-2017, 02:13 PM   #29
XDoubleXA   XDoubleXA is offline
XDoubleXA's Avatar
UPDATED!
Bike: Bashan Shark 250
Elevation: 981 ft
Carb: Stock Keihin
Jet sizes: Slow 35, Main 120
Needle setting: Clip last notch down.
Pilot screw turns: 1 3/4
Relevant mods: Ebay CRF230 Exhaust, After market needle, Uni Pod filter.
Top speed: 70MPH (GPS) Top speed. Likes to cruise around 55-60
Sprockets: 17T front, and 45T Rear.
Bashan Shark, Keihen PZ30 Carb, Pilot 40, Main 120, Uni Filter, Exhaust, MSR Shifter, and some stickers.
Old 09-26-2018, 09:43 AM   #30
wamey   wamey is offline
wamey's Avatar
Bike: 2017 Hawk
Elevation: 870ft
Carb: Mikuni VM26 Clone
Jet sizes: Genuine Mikuni Jets - 28 Pilot. 112.5 Main. Factory needle.
Needle setting: middle notch
Relevant mods: Sprockets - 17 front, 47 rear. Battlax BT45 tires. Motocheez airbox mod. PCV installed in crankcase breather tube. Front fork brace to help with front end speed wobbles.
Top speed: 68mph flat out (no wind, flat road)
