Old 11-26-2017, 12:50 AM   #3
ReconOne   ReconOne is offline
ReconOne's Avatar
Originally Posted by Merlin View Post
Check for voltage at the bulb and I bet you wont find any. If that is the case check for loose wires.
Ill have to check that tomorrow, looks like my multimeter is broken..not reading anything, even batteries.
Pulled the bulbs out to check, both look the exact same (so not burned out at least), netural comes on when it fires up (all other lights work, blinkers, hazards, brake etc) but that backlit one doesnt. These are the only two wires that are not hooked into anything...but there isnt anything for them to hook with. The one little fuse i found in a small white box like thing looks fine as well (has a second fuse there too)
