Old 01-29-2018, 10:28 AM   #301
Wolftrax   Wolftrax is offline
Wolftrax's Avatar
Engine work, ported and polished head, inspect clutch, cleaned centrifugal oil filter and last but not least will plane head and lap valves.
Mark
2015 Haosen Hawk 250
2014 CRF250L
2014 CB500X Rally Raid
Old 01-29-2018, 10:47 AM   #302
Nice job on the port work. Just curious, how many miles you have on it? How much you take off the head?
Old 01-29-2018, 11:22 AM   #303
Wolftrax's Avatar
I've got approx 4500 miles on it. I'm just going to make sure the head isn't warped, even it out.
Mark
2014 CRF250L
Old 01-29-2018, 01:57 PM   #304
Alright, another ported head added to the list! Even without the added compression it will make a nice difference in the upper RPM range and avoid the extra heat and pressure on the bearings as well. Good idea for a long distance overland build.
I saw you were looking at a 520 chain conversion as well. I have the part numbers listed in the link in my signature if you need them.
Old 01-29-2018, 06:52 PM   #305
Wolftrax's Avatar
Hey Dan, already been to the link, really appreciate having all the info in the same place.
Mark
2014 CRF250L
Old 01-30-2018, 02:51 AM   #306
It needed to be done. It's far from complete, so if you think you have some info that should be there but you don't see, then let me know.
Old 01-30-2018, 04:53 PM   #307
Wolftrax's Avatar
Waiting on parts. Gasket set, spokes, universal rear fender, chain slider, and bearings. Decided to fab up some side racks for soft bags.
Mark
2014 CRF250L
Old 01-30-2018, 05:12 PM   #308
Wolftrax's Avatar
I'd like to share my obsession with why I think the humble Hawk would make a great travel companion in the developing world. On my trip through Central and South America last year the overwhelming majority of motorcycles encountered we're Chinese CG variants, I'm talking a 1000 to every one of everything else. It occurred to me that riding my Honda CRF250L was a good choice due to it's inherent reliability however, if I ever needed a critical part and I wasn't near a large city, I was SOL. On the other hand, taller de motos ( motorcycle shops) for the locals, riding Chinese motos were everywhere. Now given the choice of of spending a couple of days or more waiting on that genuine Honda part or doing a complete engine R and R in a couple of hours at a roadside shop, the value of the Chinese bike increases.
Another thing that is totally unnecessary is big bore high HP Adv bikes. The only advantage they have is collecting speeding tickets. Crusing at 90 kph is all you really need.
Viva el Hawk.
Mark
2014 CRF250L
Old 02-04-2018, 04:12 PM   #309
Wolftrax's Avatar
After the porting and valve grind I buttoned her back up and did a compression test. Pretty happy with 165 number. Was thinking aboit at least doing a ring job, bit my cylinder looked really clean, no scoring no nothing. Not bad for a 4500 mile engine��
Mark
2014 CRF250L
Old 02-04-2018, 06:07 PM   #310
That is right around where my hawk floats as far as compression goes. I would call that pretty healthy
Old 02-05-2018, 02:35 PM   #311
Wolftrax's Avatar
Took the frame to the welder today to check the welds and straighten the foot pegs. In the interim I decided to start on the seat.
The stock seat suffers from poor quality foam and the obnoxious hump. I'm also going to make it a bit wider in the hip area.
Phase 1, remove cover, cut stock foam, measure and cut 6lb carpet pad to fit cutout. Glue in place and rough shape with knife. Need a sharpie a serrated edge knife, scissors and spray adhesive.
Mark
2014 CRF250L
Old 02-11-2018, 11:31 PM   #312
rjmorel   rjmorel is offline
rjmorel's Avatar
Wolf where do you get the 4 fingered tool for removing/ tightening the slinger nut ? rj
Live Zong, and Prosper
Old 02-12-2018, 08:59 AM   #313
This will work for the clutch and centrifugal oil filter.
https://www.ebay.com/itm/Honda-Oil-F...lZX~UP&vxp=mtr
https://www.motosport.com/product/?a...segment=badger
You can also take an old socket and grinder and make you own.
Old 02-12-2018, 05:25 PM   #314
Wolftrax's Avatar
I just use a punch and a 5lb hammer. Been using that method for years and nary a problem.
Mark
2014 CRF250L
Old 02-12-2018, 05:39 PM   #315
Wolftrax's Avatar
Got the the tank cleaned up. Also chopped 6" off the seat to make room for an Acerbis auxiliary tank to mount on the frame rails. The seat came out pretty well if I say so myself. It's wider, flatter and firmer.
Mark
2014 CRF250L
